we need use DisplayPort2 with jetson orin, in design guide,module pin D51(HDMI_DP2_TX0_P) Description is DisplayPort 2 Lane 0 .
but in pinmux customer usage ,module pin D51 has 3 option,whitch one should i choose(HDMI_DP0_TXDP2/DP0_TXDP2/HDMI0_TXDP0?)
Hi, you can choose any one of three based on your usage. Changing the pinmux settings for the Dedicated SFIOs will not affect the register settings (as you can see in the output DT files from pinmux sheet). They are shown only for informational purposes.
