Hi, does Jetson AGX xavier devkit support SD card Image booting? if yes where can I get SD card Image for this?
Else please guide me how to flash nvida image to devkit
No, there is no SD card image for AGX Xavier.
How to flash devkit image? using SDK manager? will device gets detected as devkit?
Ok, I have connected devkit with 32gb module and put it into force recovery mode and then in host machine I can see Jetson AGX xavier modules with part number, but it is not showing devkit specifically, should that be OK?
Theoretically, you should have seen your devkit on sdkmanager. Try to select manually and flash it with this way.
