Hi, we want to power NVIDIA Jetson AGX Xavier from the TDK-Lambda HWS100A-24 source by setting the voltage to source output 19.2V. Xavier will work normally in such conditions or there are some analogs of this source, in this execution?
Hi, it is OK for general use case running.
The real power consumption depends on your custom application. The design IDDmax of Xavier module is 5.4A @ VIN_HV (20V) and 6A @ VIN_MV(5V) as you can see in module datasheet.
