hello,
请问Jetson Linux r36.3能安装Jetpack 5.x吗?默认使用apt install nvidia-jetpack是6.x版本。
hello,
Hi weiyf1,
Are you using the devkit or custom board for Orin NX?
Orin NX is compatible with Jetpack 5.x
You can flash it with the latest Jetpack 5.1.4 (L4T R35.6.0).
Hi Kevin,
I using custom board for Jetson Orin NX, my customer has developed an AI project based on Jetpack 5. X on r35. x, but is currently facing obstacles in porting it to our BSP r36.3 board.
I am considering whether I can only downgrade BSP from 36.x to 35.x, as the significant environmental changes in 36.x and 35.x make it difficult to handle Jetpack dependencies.
It seems you want to use Jetpack 5.x on your custom carrier board.
Have you ported the necessary components for your custom carrier board on JP5.x release?
(i.e. do you have custom BSP package of R35.X for your custom carrier board?)
If so, you can just use initrd flash command to flash JP5.x (R35.x).
