Hello, I had a previously fully-functioning and running OS on my Jetson Nano 2GB Dev Kit. I decided to do a fresh install on my SD card (Samsung EVO 32GB) and after finishing OS configurations and rebooting, it got stuck on a reboot loop. I tried re-installing the image on the SD card again and now I couldn’t get past the reboot loop. I tried different versions of the 2GB Dev Kit including from the SDK Manager(extracted the .img from a VM) and none got me past the boot loop. I had not changed anything on the Jetson Nano and it had been running well previously. I tried using a bench top power supply to directly power it and it still didn’t get past the boot loop.
I searched similar forum posts and the cause for their issues was a bad power supply or incorrect image flashed on to SD card but I verified multiple times that it was indeed the 2GB version and I had also used my Raspberry Pi’s spare power supply along with a benchtop power supply to verify.
I am puzzled as to what the issue is now.
I am using the same exact image that worked initialy, the same power supply and the same HDMI cable and monitor. I already tried using different power cables and the issue still remains. One thing to note is that I am flashing the SD card using the process explained on the setup page.
Using SD card formatter to format the SD card each time and the Etcher to flash the SD card.
From this I can only think the SD card is faulty and I already ordered a 64GB one, but while I wait I still want to exhaust all possibilities.
Any help would be appreciated. Thanks.
