Jetson Nano 4GB turn off after few secs
I have a problem with my Nano. After boot and showing a nVidia wallpaper its get dark and power diode on board turn off but but fan is still working. After reading another topics I bought a USB-TTL cable and get some log from serial console. Any suggestions? Log below:
[0000.126] [TegraBoot] (version 00.00.2018.01-l4t-33e7fa82)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.136] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.152] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x1926e1
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.217] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.223] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.257] Platform-DebugCarveout: 0
[0000.260] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.266] Non secure mode, and RB not enabled.
[0000.272] Invalid GPT Partition
[0000.287] Using BFS PT to query partitions
[0000.291] failed to load NvTbootTbootCpu from (2:0)
[0000.296] re-load NvTbootTbootCpu from (4:0)
[0000.318] Csd NumOfBlocks=122880000
[0000.377] Using GPT Primary to query partitions
[0000.385] Loading Tboot-CPU binary
[0000.765] Verifying TBC in OdmNonSecureSBK mode
[0000.776] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.783] Bootloader downloaded successfully.
[0000.788] Downloaded Tboot-CPU binary to 0xa0000258
[0000.793] MAX77620_GPIO5 configured
[0000.796] CPU power rail is up
[0000.799] CPU clock enabled
[0000.803] Performing RAM repair
[0000.805] Updating A64 Warmreset Address to 0xa00002e9
[0000.811] Loading NvTbootBootloaderDTB
[0002.133] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0002.205] Bootloader DTB Load Address: 0x83000000
[0002.209] Loading NvTbootKernelDTB
[0003.531] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0003.603] Kernel DTB Load Address: 0x83100000
[0003.611] Loading cboot binary
[0005.309] Verifying EBT in OdmNonSecureSBK mode
[0005.351] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0005.358] Bootloader downloaded successfully.
[0005.551] Using BFS PT to query partitions
[0005.555] Next binary entry address: 0x92c00258
[0005.560] BoardId: 3448
[0005.564] Overriding pmu board id with proc board id
[0005.569] Display board id is not available
[0007.081] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0007.137] /bpmp deleted
[0007.139] SC7EntryFw header found loaded at 0xff700000
[0007.327] OVR2 PMIC
[0007.329] Bpmp FW successfully loaded
[0007.346] WB0 init successfully at 0xff780000
[0007.350] Set NvDecSticky Bits
[0007.354] GSC2 address ff53fffc value c0edbbcc
[0007.360] GSC MC Settings done
[0007.365] TOS Image length 53680
[0007.368] Monitor size 53680
[0007.371] OS size 0
[0007.533] Secure Os AES-CMAC Verification Success!
[0007.538] TOS image cipher info: plaintext
[0007.542] Loading and Validation of Secure OS Successful
device Read Time = 12 ms, Read Size = 65 KB
[0007.590] Sec Bot took -1554975 us
[0007.615] CPU initialization took 2057327ice trusty_fast
ice trusty_fast
ice trusty_fast
ice trusty_fast
ice trusty_fast
[0007.746] RamCode = 0
[0007.790] EMC Training Successful
[0007.793] 408000 not found in DVFS table
[0007.833] RamCode = 0
[0007.839] DT Write: emc-table@204000 succeeded
[0008.066]
[0008.067] Debug Init done
[0008.069] Marked DTB cacheable
[0008.072] Bootloader DTB loaded at 0x83000000
[0r tick-timer
[0008.120] Using base:0x60005098 for delay-timertors
[0008.149] initializing heap
[0008.152] initializing threads
[0008.155] initializing timers
[0008.158] creating booID LSB = 0x36, ID-CFI len = 194 bytes
[0008.190] Macronix QSPI chip present
[0008.193] SPI device register
[0008.196] inindle 0x5b
[0008.225] sdcard gpio pin 0xc9
[0008.228] sdcard ise CSD data
[0008.284] Send command 7
[0008.295] Calling sd device register
[0008.298] Init sdcard
[0008.329] of_register: registering inv20628-driver to of_hal[0008.364] gpio frd
[0008.368] of_register:istering i2c_bus_driver to of_hal
[0008.395] pmic framework igdriver
[0008.429] board ID = D78, board SKU = 0
[0008.433] Skipping Z3!
[0008.489] I2C Bus Init done
[0008.491] of_children_init: Ops[0008.530] I2C Bus Init done
[0008.532] of_children_init: Ops ‘max77620-gpio’ driver
[0008.573] of_children_init: Ops foun[0008.613] Find /i2c@7000c500’s alias i2c2
[0008.617] get eepeprom_init: EEPROM read failed
[0008.643] pm_ids_update: eeprom init failed
[0008.647] pm_ids_update: Updating 3,a0, size 256, type 0
[0008.677] pm_ids_update: The pm board id is 3448-0000-200
[0008.685] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0008.693] pm_ids_update: pm id update successfuf)
[0008.779] shim_eeprom_update_mac:267: Failed to update 0 [0008.821] shim_cmdli
size 256, type 0
[0008.864] pm_ids_update: Updating 1,a0, siz008.923] Adding plugin-manager/ids/0
[0008.930] pm_ids_update: pm id update successful
[0008.934] pm_ids_update: Updating 3,ae, size 256, type 0
008.971] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500[0009.024] platfog
[0009.028] calling apps_init()
: HDMI not conn[0009.132] subnode volume_up is not found !
[0009.136] subnode back is not found !
[0009.140] subnode volume_down is not found !
[0009.144] subnode menu is not found !
[0009.148] Gpio keyboard init success
[0009.198] found decompressor handler: lz4-legacy
[0009.212] decompressing blob (type 1)…
[0009.278] display_resolution: No display init
[0009.282] Failed to retrieve display resolution
[0009.287] Could not load/initialize BMP blob…ignoring
[0009.292] -------> se_aes_verify_sbk_clear: 747
[0009.296] se_aes_verify_sbk_clear: Error
[0009.300] SE operation failed
[0009.303] bl_battery_charging: connected to external power supply
[0009.313] display_console_ioctl: No display init
[0009.318] switch_backlight failed
[0009.324] device_query_partition_size: failed to open partition sd0:MSC !
[0009.330] MSC Partition not found
[0009.337] device_query_partition_size: failed to open partition sd0:USP !
[0009.343] USP partition read failed!
[0009.347] blob_init: blob-partition USP header read failed
[0009.352] android_boot Unable to update recovery partition
[0009.358] kfs_getpartname: name = LNX
[0009.361] Loading kernel from LNX
[0009.500] load kernel from storage
[0009.512] decompressor handler not found
[0009.596] Successfully loaded kernel and ramdisk images
[0009.601] board ID = D78, board SKU = 0
[0009.606] sdmmc node status = okay
[0009.609] sdcard instance = 0
[0009.612] sdmmc cd-inverted
[0009.615] sdcard gpio handle 0x5b
[0009.618] sdcard gpio pin 0xc9
[0009.621] sdcard gpio flags 0x0
[0009.624] vmmc-supply 0x9d
[0009.626] cd_gpio_pin = 201
[0009.629] pin_state = 0
[0009.631] Found sdcard
[0009.634] SD-card IS present …
[0009.637] load_and_boot_kernel: SD card detected OK
[0009.643] display_resolution: No display init
[0009.647] Failed to retrieve display resolution
[0009.652] bmp blob is not loaded and initialized
[0009.656] Failed to display boot-logo
[0009.660] NCK carveout not present
[0009.663] Skipping dts_overrides
[0009.666] NCK carveout not present
[0009.677] Find /i2c@7000c000’s alias i2c0
[0009.681] get eeprom at 1-a0, size 256, type 0
[0009.691] Find /i2c@7000c500’s alias i2c2
[0009.695] get eeprom at 3-a0, size 256, type 0
[0009.699] get eeprom at 3-ae, size 256, type 0
[0009.704] pm_ids_update: Updating 1,a0, size 256, type 0
[0009.709] I2C slave not started
[0009.712] I2C write failed
[0009.715] Writing offset failed
[0009.718] eeprom_init: EEPROM read failed
[0009.722] pm_ids_update: eeprom init failed
[0009.726] pm_ids_update: Updating 3,a0, size 256, type 0
[0009.756] pm_ids_update: The pm board id is 3448-0000-200
[0009.763] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0009.772] pm_ids_update: pm id update successful
[0009.776] pm_ids_update: Updating 3,ae, size 256, type 0
[0009.806] pm_ids_update: The pm board id is 3449-0000-200
[0009.813] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0009.821] pm_ids_update: pm id update successful
[0009.851] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0009.857] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0009.865] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0009.871] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0009.880] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:51:77
[0009.886] Plugin Manager: Parse ODM data 0x00084000
[0009.900] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x7
[0009.908] Add serial number:1422019084521 as DT property
[0009.918] “bpmp” doesn’t exist, creating
[0009.924] Updated bpmp info to DTB
[0009.929] Updated initrd info to DTB
[0009.932] “proc-board” doesn’t exist, creating
[0009.939] Updated board info to DTB
[0009.942] “pmu-board” doesn’t exist, creating
[0009.948] Updated board info to DTB
[0009.951] “display-board” doesn’t exist, creating
[0009.957] Updated board info to DTB
[0009.961] “reset” doesn’t exist, creating
[0009.965] Updated reset info to DTB
[0009.969] display_console_ioctl: No display init
[0009.973] display_console_ioctl: No display init
[0009.978] display_console_ioctl: No display init
[0009.982] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype
[0010.017] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0010.022] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[0010.036] Updated bootarg i system-lp0-disable info to DTB
[0010.072] set vdd_core voltage to 1125 mv
[0010.076] setting ‘vdd-core’ regulator to 1125000 micro volts
[0010.082] Found secure-pmc; disable BPMP
U-Boot 2020.04-00004-gc4505b0cac (Jun 24 2023 - 17:15:35 +0100)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM: 4 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash… SF: Detected mx25u3235f with page size 25B
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
845 bytes read in 23 ms (35.2 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
7159654 bytes read in 329 ms (20.8 MiB/s)
Retrieving file: /boot/Image
34748424 bytes read in 1538 ms (21.5 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resiz
Flattened Device Tree blob at 83100000
Booting using thcopying carveout for /host1x@50000000/dc@54200000…
copying carveout for /host1x@50000000/dc@54240000…
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.299-belabox (cosmin@belabox-4gb) (gcc version 3
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 1.063652] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.569379] Host read timeout at address 545c00c4
Hi reeback,
Are you using the devkit or custom board for Jetson Nano?
Are you booting from SD card?
If so, please change another SD card and also refer to the following topic.
JetsonNanoB01 can not login
Hi KevinFFF,
Im using the devkit. After question about JetPack I will try to reinstall/update it.
Im booting it from SD card, I tried 2 different cards (SanDisc Ultra A1 16GB and Goodram XC 64GB) and tried to upload .iso by etcher and rufus, theres no change.
Could you get a standalone Ubuntu 18.04 as your host and use SDKM to flash the board?
No, I cant. The only way for me is a virtual machine.
/edit
I found an old notebook and I will try with Ubuntu in free time and share it with you.
