Our Nano module seems to have an issue with the autologin. After flashing the p3449-0000+p3448-0002 profile on our module, and selecting autologin during the initial setup, the autologin will fail intermittently when rebooting. We have observed this on JetPack 4.4.1 and 4.5. This is our /etc/gdm3/custom.conf file:
# GDM configuration storage
# See /usr/share/gdm/gdm.schemas for a list of available options.
[daemon]
AutomaticLoginEnable=true
AutomaticLogin=n
# Uncoment the line below to force the login screen to use Xorg
WaylandEnable=false
# Enabling automatic login
# Enabling timed login
# TimedLoginEnable = true
# TimedLogin = user1
# TimedLoginDelay = 10
[security]
[xdmcp]
[chooser]
[debug]
# Uncomment the line below to turn on debugging
# More verbose logs
# Additionally lets the X server dump core if it crashes
#Enable=true
We have also tried editing /etc/lightdm/lightdm.conf.d/50-nvidia.conf to include:
autologin-user=nvidia
autologin-user-timeout=0
Looking at the output of “sudo journalctl -b” I found that when auto login failed, the following appeared:
Mar 23 15:39:13 n-desktop /usr/lib/gdm3/gdm-x-session[5142]: (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so Mar 23 11:22:13 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (II) Loading sub module "glxserver_nvidia" Mar 23 11:22:13 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (II) LoadModule: "glxserver_nvidia" Mar 23 11:22:13 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so Mar 23 11:22:13 n-desktop NetworkManager[4235]: <info> [1616512933.9710] devices added (path: /sys/devices/virtual/net/lo, iface: lo) Mar 23 11:22:13 n-desktop NetworkManager[4235]: <info> [1616512933.9711] device added (path: /sys/devices/virtual/net/lo, iface: lo): no ifupdown configuration found. Mar 23 11:22:14 n-desktop NetworkManager[4235]: <info> [1616512934.0000] devices added (path: /sys/devices/virtual/net/dummy0, iface: dummy0) Mar 23 11:22:14 n-desktop NetworkManager[4235]: <info> [1616512934.0001] device added (path: /sys/devices/virtual/net/dummy0, iface: dummy0): no ifupdown configuration found. Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (II) Module glxserver_nvidia: vendor="NVIDIA Corporation" Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: compiled for 4.0.2, module version = 1.0.0 Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: Module class: X.Org Server Extension Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (II) NVIDIA GLX Module 32.5.0 Release Build (integ_stage_rel) (buildbrain@mobile-u64-4415) Fri Jan 15 14:43:01 PST 2021 Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA graphics device! Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (EE) NVIDIA(0): Failing initialization of X screen 0 Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (II) UnloadModule: "nvidia" Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (II) UnloadSubModule: "glxserver_nvidia" Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (II) Unloading glxserver_nvidia Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (II) UnloadSubModule: "wfb" Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (II) UnloadSubModule: "fb" Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (EE) Screen(s) found, but none have a usable configuration. Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (EE) Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: Fatal server error: Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (EE) no screens found(EE) Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (EE) Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: Please consult the The X.Org Foundation support Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: at http://wiki.x.org Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: for help. Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information. Mar 23 11:22:14 n-desktop /usr/lib/gdm3/gdm-x-session[5251]: (EE)
I did not see the “Failed to initialize the NVIDIA graphics device!” message when the autologin succeeded. The output of “/var/log/Xorg.0.log” (well, “/var/log/Xorg.0.log.old” actually, as the non-autologin session created a new “/var/log/Xorg.0.log” right after this one failed) was:
xorg.txt (8.0 KB)
Could someone investigate why this happens? Thank you.
