tech27
March 4, 2021, 12:28pm
24
Hi WayneWWW,
As per your suggestion in below link
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/flashing.html#wwpID0E0HM0HA
We have done All 6 steps successfully. Now for 7th step we need to put device in recovery mode for that we followed below step as per this link reference.
I have done:
1.Jumper the Force Recovery pins (3 and 4) on J40 button header
2.Jumper the J48 Power Select Header pins and connect a power supply to J25 power jack
and run in host linux sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
the result is :
L4T BSP Information:
R32 , REVISION: 2.0
Error: probing the target board failed.
Jumper the J48 power select pin first and plug the power jack
Jumper the recovery pin
Jumper the reset pin
Remove the jumper of reset pin
Remove the jumper of recovery pin.
But it is not working.
Search the keyword recovery mode in below document.
Your board definitely can enter recovery mode or your previous work on sdkmanager is not completed.
The flash process can only starts when the board is in recovery mode.
tech27
March 5, 2021, 8:57am
26
Hi WayneWWW,
We had done all the steps successfully. I glad to inform you that now we are able to boot jetson nano board from SSD without using memory card.
I would like to appreciate you for your quick support and valuable inputs.
Thank you.
