Jetson Nano booting up to TinyLinux
Hi, we are seeing a lot of issues that Jetson nano booting up to TinyLinux on some of our Nanos with a verified known good base OS image. It comes up as USB with 0955:7118 NVidia Corp, which is not the number listed in any document. Attached the kernel log. booting_tinylinux.txt (65.5 KB) . Could you help let us know what’s the problem here? Thank you.
It looks like we have many things to check here
  1. Do you mean only some jetson nano modules have such issue while others don’t?
  2. If you don’t use TinyLinux, would you see usb device 7118 on that nano?
  3. I see your error log says
“Starting mount…mount: mounting UUID=b39a7ef2-3c11-442b-bddc-519b1c9728c7 on /home failed: No such file or directory”
Are you even trying to mount rootfs from external drive?
