These are my equipments:
5V/5A power supply with barrel jack (j48 pins closed)
Mouse, keyboard and monitor(i tried both hdmi and dp output)
128gb KIOXIA EXCERIA microSD card
I flashed my sd card properly and put into jetson but there is a green light only on the board, there is no power on mouse, keyboard or hdmi signal
What is the problem? Please can you hep me!!!
Please use serial console to check log. If there is log but your board cannot boot up, then please flash your board with sdkmanager.
Hi, thank you for your suggestion. I did things that done in the applicaiton but jetson nano doesnt booted. My console results in below, what should i do now?
And also, when i powered my jetson nano green power light start blink constantly.
If the power light is unstable, it looks like more like a hardware problem.
I solved blinking problem i thing it was about ftdi switch 5v, i changed as 3.3v. Now, i will try to SDK Manager method as last chance.
