Hi everyone,
I follow this blog to implement the Jetson Nano + intel AX200 for being sniffer to capture wifi 6’s packets. You too can have a sub-$200 .11ax client – Hypergeek Wi-Fi
Everything went smooth until I reboot and enable WiFi networking, you can check from below picture I can actually detect APs signal. But Jetson Nano would shutdown soon, I can not connect internet via wifi. In fact, most of time when I enable WiFi function, Jetson Nano would directly shutdown and reboot by itself.
First in my mind is beacuse of power supply, but when I changed the power from microUSB to DC power jack (also put the jumper on J48). Jetson Nano would still shutdown and reboot by itself.
Moreover, the Jetson Nano board I used is A02.
How can I solve this problem?
