jetson nano kartını fabrika ayarlarına döndüremiyorum nasıl döndüreceğim konusunda yardımcı olur musunuz ?
I’m not sure what you mean the Jetson Nano card can’t restore to factory setting, have you checked and followed the Get Started With Jetson Nano Developer Kit | NVIDIA Developer?
You can also check Jetson Nano FAQ - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums to do the debug first.
- Are these development kits sold by NVIDIA?
- Or do they have a third party manufacturer carrier board?
- If these have eMMC memory, then they must be third party manufactured (the carrier board portion).
- In no case do the “force recovery” pins reset the installed software, this only puts the Jetson in a mode which allows flash software running on an Ubuntu 18.04 (or 16.04) desktop PC to flash (the flash information is what @kaycccc mentioned). Actual flash is required to change anything.
- NVIDIA dev kits have the SD card slot on the module itself; third party carrier boards have the SD card on the carrier board. The software used is different between the two models.
- An SD card model (NVIDIA development kit) gets the operating system on the SD card, but all of the boot content, and the content equivalent to what a BIOS would do, is on QSPI memory on the module. An SD card is not reset by flash, but QSPI memory is reset by flash. The QSPI and SD card must be compatible release versions in order for boot to succeed.
- Third party carrier boards usually have a different device tree (firmware). The manufacturer provides that software for flash. Boot content (and equivalent of the BIOS) normally lives on eMMC for those models.
