I have flashed images in microSD card and first time start jetson nano. But “Android Boot Menu” appeared on the screen, and then stuck at “continue booting”.
I think it has nothing to do with this microSD card, because i changed some other microSD cards, or i even don’t insert a microSD card, but the same situation always occured.
Suggest to use sdkmanager/jetpack to flash your board first:
- Prepare a Ubuntu 18.04 host with proper environment.
- Download and launch sdkmanager on this host.
Install Jetson Software with SDK Manager :: NVIDIA SDK Manager Documentation - Put the board into recovery mode and connect micro usb cable. If entering RCM (recovery mode) correctly, your host should see nvidia corp with command “lsusb”
- Start the flash procedure by sdkmanager GUI tool.
