the initial bott happened very quickly without me setting up anything and since then it’s asking me for a password that I did not setup. the username is jetson but I have no idea about the password, I reflshed the card with the image but when I attach it I see the same logic page
- Are you flashing the Jetson using the SDK Manager or performing a manual flash?
- If you are using the SDK Manager, it includes a preconfiguration option to set up the account and password.
- If you are flashing manually, please run
l4t_create_default_user.shfirst before proceeding with the flash. - What is your Ubuntu Version?
- Is your Ubuntu running on physical machine or the virtualmachine?
Hello, I am performing a manual flash. Where to find this script “l4t_create_default_user.sh” since none of the resources I went through mentioned this script. Also where and when to run this script.
It would be helpful if you could provide the link for the steps.
Also, the image I have used is the "Jetson Nano Developer Kit SD Card Image "
The script l4t_create_default_user.sh is located at Linux_for_Tegra/tools/l4t_create_default_user.sh.
You can refer to this Quick Start Guide to manually flash the device. The provided link is for JetPack 4.6.5, but you can find a similar guide for your specific JetPack version to complete the installation.
