I have a JETSON NANO connected with 5V everything worked as it should.
After connecting a MIPI camera the JETSON NANO does not turn on.
When I connect the JETSON NANO with USB to the PC, I do not recognize the board.
Could it be that a bad connection of the camera burned the board?
Has anyone encountered the problem and managed to solve it?
This forum is dedicated to network devices such as ethernet switches. I would try asking this question in a different forum such as one of the Jetson ones here → Jetson & Embedded Systems - NVIDIA Developer Forums
I will move this topic to the Jetson forums.
hello guy.ford.green2pass,
please setup a serial console and gather the booting logs for reference,
you may see-also https://jetsonhacks.com/2019/04/19/jetson-nano-serial-console/ for reference.
