Hello, I am using jetson nano 4Gb module our project in which three usb ports are working and 1 usb port is not working I don’t know what is the issue.To complete the setup I need all the other ports to be working and when I use the multiple usb socket ,it keeps on changing the ports in the code. How do is solove this ?
Please help me
Thanks in advance
Welcome to the NVIDIA forums! Your issue may get better exposure in the Jetson forums. I am moving it over for you.
Tom
Do you use Jetson Nano developer kit? There is embedded USB hub in the developer kit and probably it is damaged. Does it happen in one specific port?
