Is the Jetson Nano 260 pin SODIMM connector pinout the same on all 3 modules (Production Module vs Dev Kit Module vs Dev Kit 2GB Module)?
Could I use either Dev Kit module on a custom carrier board during development, and then transition to the Production Module at a later date?
Thank you!
kayccc
2
For Production Module and Dev Kit Module, yes. I’m not sure for 2GB module.
Yes, start from Dev Kit module on developing then transition to the Production Module. The Nano 2GB module is not for production purpose.
system
Closed
3
