I was wondering if the setup of Nano is the same as AGX xavier and Jetson TX2?
Previously I were using SDK manager to setup and flash the agx xavier and tx2 but for Nano I used this link: Getting Started With Jetson Nano Developer Kit | NVIDIA Developer
later I saw somewhere that they used SDK manager to setting up the Nano.
If it is possible, how it can be done? How the SD card can be flashed and configured through SDK manager? would you please share a link or tutorial.
Would you be please share an instruction or link about hoe to flash jetson nano?
Thanks for the quick reply.
2) if I choose to setup the Nano using SDK manager, I have to enter the SD card into my host machine to be processed, is that correct? this the main different from agx xavier and tx2, since they don’t need SD card, right?
3) Previously, To install a camera driver I made some changes to Image file and reboot the Nano, but after that the screen is not coming up, it is like below image. I plog-out and plog-in the Nano’s power again but the screen remained the same. So I think I need to flash the Nano.
I saw some tutorials on youtube about flashing Nano, they were using SDK manager and l4t through this link https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/flashing.html#)
BUT I can not use SDK manager due to some reasons. You mentioned I can use this link to flash the nano (Getting Started With Jetson Nano Developer Kit | NVIDIA Developer). Is it going to be the same as setting up nano from beginning?
Ok, let me explain my experience as the solution to this discussion:
There are 2 ways for setting up and installation of jetson devices, using SD card image method or NVIDIA SDK manager method. SDK manager can work for all types of jetson devices but the SD card method is specially for Nano and NX. Check this archive link: https://developer.nvidia.com/jetpack-sdk-45-archive
For Nano, it is easier and more straight forward to use SD card method, using this link: https://developer.nvidia.com/embedded/learn/get-started-jetson-nano-devkit#intro
Flashing Jetson Nano (the SD card) can be done through above link, the Etcher step, and the next steps are the same as setting up Nano for the first time. Flashing Nano can be done through SDK manager as well, like what we do for AGX xavier and TX2.
Setting up Nano for first time takes about 30 minutes and flashing it takes about 10 minutes (using SD card method).
Sdcard image won’t update the device as sdkmanger does. The bootloader firmware on the board is stored inside QSPI flash but not sdcard, so if you only change sdcard image (<= jp4.4.1), then the bootloader software won’t be updated.
