I recently flashed my Jetson Nano with both 64 GB and 128 GB SD cards. After installing JetPack 4.4, it only shows 16 GB as the root filesystem, and the remaining space appears as unallocated. I tried to fix this manually using gparted, but the data layout is unique, and I couldn’t merge the empty space with the primary (p1) root partition. What else should I try?
Thanks ~0604
Could your provide your sdk log for us to review?
