I generated an image using the Nvidia command line tool after having learned that the SDK Manager does not make use of the full capacity of a large SD card (for whatever reason).
This image I burnt using Balena Etcher on a OS X machine.
Then I expanded the partition table on a Ubuntu 22.04 using gparted
Situation of the SD card on Ubuntu Host Machine
Host machine yields 119.08 GiB card size.
Does anybody have a clue what is going on here? I have been fiddling around with getting Jetson Nano software up and running for days now and I would be really glad to start doing something more meaningful ;-)
Are you using Jetson Nano with eMMC? Is the SD card slot on the module itself or on the carrier board?
If it’s the eMMC module, I believe the 14.7 GB capacity comes from the eMMC, but not the SD card.
Thanks for reaching out. You’re absolutely right. After hours of digging in the wrong direction I found out that I am using a Waveshare board with an eMMC and SD card slot on the carrier board. Thus, the limitation came from the eMMC and the comparison I made in my original post was totally wrong (comparing eMMC with SD card). In the meantime I also got an original Jetson Nano Developer Kit from NVIDIA where there is no eMMC and the SD card slot is on the computing module itself.
I guess this is all described somewhere but it was not that obvious to me.
