after flashing the jetpack to SD card during boot it says not enough disk space
can someone help me.
i really want to flash the Jetpack 4.6 (for jetson nano) to a bigger capacity sdcard
Sorry for the late response, is this still an issue to support? Thanks
yes please i can only flash the jetpack sdk to a 32GB sdcard, if i flash it to a bigger sdcard its having some problem after flashing
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
Hi iancasarungan,
Please flash JetPack-4.6 through SDK Manager or usgin Ethcher with SD card image .
You can create username, password and set SD card size at first boot.
yes but after is set the size of the partition it says not enough memory space.
Hi iancasarungan,
After set the APP partition to maximum size, where are you see memory space not enough message?
If you can boot to Desktop success, you can use ‘df -h’ command to check your disk space.
Please provide the log or picture for check, thanks!
Hi iancasarungan,
Please check SD card on your host machine.
You can use below command to format SD card, then flash again.
$ sudo mkfs.ext4 /dev/sd<x>
