I’m trying to solve an issue of display but I just couldn’t get it to work. It tried to play with these LCD panels on Raspberry pi with /boot/config.txt and everything works. But when I connect them to Jetson Nano the real fun begins…
When I boot with new kernel display shows picture as it should but it flickers so much you can’t watch the display. The strangest thing about it is that if I reconnect this screen to Raspberry Pi it also flickers and it looks like Jetson did something to the screen - I know it sounds strange but it looks like it was somehow reprogrammed through HDMI port.
Did anyone else had problems with flickering display?
Hello @WayneWWW, thanks for replay and pointers. While waiting for answer I was searching through forum and found this post (VR display for jetson nano - #5 by Lissanro). The result is the same on both procedures - with your help and solution on this post.
Boot up Nano with disconnected MIPI board, after system is booted I connect LCD panel and everything is perfect. If I disconnect LCD panel reboot system connect it again, LCD starts to flicker. It doesn’t matter to which system I connect it after this, it will flicker (Raspberry Pi, Windows laptop). If I disconnect LCD panel, wait for 3h screen won’t flicker but if I repeat procedure it starts to flicker again. I tried this on three different MIPI boards and LCD panels and result is the same.
I can’t get it to flicker no matter how and where I connect it just that Jetson Nano isn’t included.
Ok, so you are using a MIPI → HDMI converter here and directly connect on the jetson nano’s HDMI port.
If you can see the desktop on your panel without the patch, then I don’t think that patch you used from that post would help.
That patch only takes effect for cases that you totally not able to see the correct mode. Our driver filters this mode out because the hardware may not support it well.
For the flicker issue, you can dump the dmesg and check the pclk. See if this pclk is what you expect. But as I said, it may not support well for such mode.
I can’t find anything like it? We need 5.5inch with 2560x1440 LCD panel - I know this isn’t the place to ask, but do you have any suggestions (link) what to buy?
No, this is just HDMI connected to PC - USB port is connected to USB charger directly. You can change resolution but it doesn’t look good any more… just more “advanced” tool to set resolution on windows PC…
