hi
i’ve tried upgrading the jetson agx xavier to ubuntu 20.04 unsuccessfully many times on different platforms
it keeps saying there is a problem with the jetson
hi
May I know how do you do the upgrade?
Have you tried to use the SDK manager to flash your device?
I have tried several things. My host is ubuntu 24 so i had to run the docker image for ubuntu 20 that nvidia provides but it failed once it started flashing. I tried wsl on windows with ubuntu 20 but the same error occurred. The windows version told me to completely reinstall the os on the jetson but i couldn’t figure that out. I tried a virtual box with ubuntu 20 and the sdk for that and it still didn’t work. I think it might be a disconnect with these virtual machines and containers once it starts flashing. Nvidia specifically recommended the wsl method but that failed.
Please download target bsp and rootfs to manually flash the device using ubuntu 24.04.
Take r35.6.4 for example.
Please download Driver Package (BSP) and Sample Root Filesystem and follow the Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation guide to flash your device.
I thought the xavier agx can’t support later than ubuntu 20.04
no it’s resolved
Please refer to this reply Sdkmanager on ubuntu 20 does not support Jetson Nano, nor TX2, nor TX1 - #11 by linuxdev
