- Step 1
I log in via serial console frome my PC and run “dmesg --follow
” ,get the following logs:
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Chip revision : A02P
[0000.044] I> Bootrom patch version : 15 (correctly patched)
[0000.050] I> ATE fuse revision : 0x200
[0000.053] I> Ram repair fuse : 0x1
[0000.056] I> Ram Code : 0x0
[0000.059] I> rst_source : 0x0
[0000.061] I> rst_level : 0x0
[0000.065] I> Boot-device: QSPI
[0000.068] I> Qspi flash params source = brbct
[0000.072] I> Qspi using bpmp-dma
[0000.075] I> Qspi clock source : pllp
[0000.078] I> QSPI Flash Size = 32 MB
[0000.081] I> Qspi initialized successfully
[0000.086] I> Active Boot chain : 1
[0000.089] I> Boot-device: QSPI
[0000.091] I> Qspi flash params source = brbct
[0000.097] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.105] I> Temperature = 24000
[0000.108] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.112] W> Skipping boost for clk: BPMP_APB
[0000.116] W> Skipping boost for clk: AXI_CBB
[0000.120] W> Skipping boost for clk: AON_CPU_NIC
[0000.125] W> Skipping boost for clk: CAN1
[0000.128] W> Skipping boost for clk: CAN2
[0000.133] I> Boot-device: QSPI
[0000.135] I> Boot-device: QSPI
[0000.138] I> Qspi flash params source = mb1bct
[0000.142] I> Qspi using bpmp-dma
[0000.145] I> Qspi clock source : pllc_out0
[0000.149] I> Qspi reinitialized
[0000.152] I> Qspi flash params source = mb1bct
[0000.157] I> ECC region[0]: Start:0x0, End:0x0
[0000.162] I> ECC region[1]: Start:0x0, End:0x0
[0000.166] I> ECC region[2]: Start:0x0, End:0x0
[0000.170] I> ECC region[3]: Start:0x0, End:0x0
[0000.174] I> ECC region[4]: Start:0x0, End:0x0
[0000.178] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.184] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.188] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.193] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.197] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.203] E> FAILED: Thermal config
[0000.210] E> FAILED: MEMIO rail config
[0000.220] I> Boot-device: QSPI
[0000.223] I> Qspi flash params source = mb1bct
[0000.232] I> Qspi flash params source = mb1bct
[0000.244] I> Qspi flash params source = mb1bct
[0000.310] I> Qspi flash params source = mb1bct
[0000.319] I> Qspi flash params source = mb1bct
[0000.346] I> Qspi flash params source = mb1bct
[0000.358] I> MB1 done
▒▒▒▒main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.367] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-2dfe4beb)
[0000.367] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.368] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.368] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.374] W> device prod register failed
[0000.378] I> Boot-device: QSPI
[0000.381] I> Boot_device: QSPI_FLASH instance: 0
[0000.386] I> QSPI Flash Size = 32 MB
[0000.392] I> Qspi initialized successfully
[0000.393] I> qspi flash-0 params source = boot args
[0000.397] E> Failed: Unknown device 6
[0000.404] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.407] I> Active Boot chain : 1
[0000.410] I> parsing oem signed section of bpmp-fw header done
[0000.416] I> bpmp-fw binary init read from storage
[0000.420] I> oem authentication of bpmp-fw header done
[0000.434] I> bpmp-fw binary done read from storage
[0000.435] I> bpmp-fw: Authentication init Done
[0000.436] I> parsing oem signed section of cpubl header done
[0000.440] I> cpubl binary init read from storage
[0000.444] I> bpmp-fw: Authentication Finalize Done
[0000.449] I> oem authentication of cpubl header done
[0000.456] I> cpubl binary done read from storage
[0000.458] I> cpubl: Authentication init Done
[0000.462] I> parsing oem signed section of rce header done
[0000.467] I> rce binary init read from storage
[0000.472] I> Relocating BR-BCT
[0000.475] I> cpubl: Authentication Finalize Done
[0000.479] I> oem authentication of rce header done
[0000.484] I> rce binary done read from storage
[0000.488] I> rce: Authentication init Done
[0000.492] I> parsing oem signed section of ape header done
[0000.497] I> ape binary init read from storage
[0000.502] I> rce: Authentication Finalize Done
[0000.506] I> oem authentication of ape header done
[0000.510] I> ape binary done read from storage
[0000.515] I> ape: Authentication init Done
[0000.519] I> parsing oem signed section of tos header done
[0000.524] I> tos binary init read from storage
[0000.528] I> ape: Authentication Finalize Done
[0000.533] I> oem authentication of tos header done
[0000.539] I> tos binary done read from storage
[0000.541] I> tos: Authentication init Done
[0000.546] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.552] I> bpmp-fw-dtb binary init read from storage
[0000.556] I> tos: Authentication Finalize Done
[0000.562] I> oem authentication of bpmp-fw-dtb header done
[0000.566] I> bpmp-fw-dtb binary done read from storage
[0000.571] I> bpmp-fw-dtb: Authentication init Done
[0000.576] I> parsing oem signed section of cpubl-dtb header done
[0000.582] I> cpubl-dtb binary init read from storage
[0000.586] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.633] I> oem authentication of cpubl-dtb header done
[0000.634] I> cpubl-dtb binary done read from storage
[0000.634] I> cpubl-dtb: Authentication init Done
[0000.635] I> parsing oem signed section of eks header done
[0000.636] I> eks binary init read from storage
[0000.637] I> cpubl-dtb: Authentication Finalize Done
[0000.637] I> oem authentication of eks header done
[0000.642] I> eks binary done read from storage
[0000.646] I> eks: Authentication init Done
[0000.650] I> eks: Authentication Finalize Done
[0000.654] I> EKB detected (length: 0x410) @ VA:0x52705400
▒▒NOTICE: BL31: v1.3(release):41d46a9cf
NOTICE: BL31: Built : 21:14:52, Jun 25 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing .......
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 57f8a77779f848bf2ecf21dabee5645f
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
mrq initialized
[0000.997] I> Welcome to Cboot
▒▒WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
▒▒[0000.997] I> Cboot Version: t194-18fdfe28
[0000.999] I> CPU-BL Params @ 0xf2820000
[0001.003] I> 0) Base:0x00000000 Size:0x00000000
[0001.007] I> 1) Base:0xf1100000 Size:0x00100000
▒▒clk_set_parent failed for clk can1, parent pll_aon (-22)
clk_set_parent failed for clk can2, parent pll_aon (-22)
clk_set_parent failed for clk dmic5, parent pll_aon (-22)
clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_set_parent failed for clk spi2, parent pll_aon (-22)
clk_set_parent failed for clk pwm4, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ▒▒[0001.012] I> 2) Base:0xf2000000 Size:0x00200000
[0001.191] I> 3) Base:0xf1200000 Size:0x00200000
[0001.196] I> 4) Base:0xf1000000 Size:0x00100000
[0001.200] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.205] I> 6) Base:0xf3800000 Size:0x00400000
[0001.209] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.214] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.218] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.223] I> 10) Base:0xf3000000 Size:0x00800000
[0001.227] I> 11) Base:0x40000000 Size:0x00040000
[0001.232] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.236] I> 13) Base:0x40046000 Size:0x00002000
[0001.241] I> 14) Base:0x40048000 Size:0x00002000
[0001.245] I> 15) Base:0xac000000 Size:0x00004000
[0001.250] I> 16) Base:0x4004a000 Size:0x00002000
[0001.254] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.258] I> 18) Base:0x4004c000 Size:0x00002000
[0001.263] I> 19) Base:0xf2200000 Size:0x00600000
[0001.267] I> 20) Base:0x4004e000 Size:0x00002000
[0001.272] I> 21) Base:0xf09d0000 Size:0x0000c000
[0001.276] I> 22) Base:0x00000000 Size:0x00000000
[0001.281] I> 23) Base:0xf09e0000 Size:0x00020000
[0001.285] I> 24) Base:0xf6000000 Size:0x02000000
[0001.290] I> 25) Base:0x40050000 Size:0x00002000
[0001.294] I> 26) Base:0x40040000 Size:0x00006000
[0001.299] I> 27) Base:0xf1800000 Size:0x00400000
[0001.303] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.308] I> 29) Base:0xf1400000 Size:0x00400000
[0001.312] I> 30) Base:0xf0a00000 Size:0x00100000
[0001.316] I> 31) Base:0x00000000 Size:0x00000000
[0001.321] I> 32) Base:0xf8000000 Size:0x08000000
[0001.325] I> 33) Base:0x00000000 Size:0x00000000
[0001.330] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.334] I> 35) Base:0xab000000 Size:0x01000000
[0001.339] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.343] I> 37) Base:0xf2800000 Size:0x00800000
[0001.348] I> 38) Base:0x80000000 Size:0x20000000
[0001.352] I> 39) Base:0xb0000000 Size:0x08000000
[0001.357] I> 40) Base:0x00000000 Size:0x00000000
[0001.361] I> 41) Base:0x00000000 Size:0x00000000
[0001.366] I> 42) Base:0x00000000 Size:0x00000000
[0001.370] I> 43) Base:0x00000000 Size:0x00000000
[0001.374] I> 44) Base:0x00000000 Size:0x00000000
[0001.379] I> 45) Base:0x00000000 Size:0x00000000
[0001.383] GIC-SPI Target CPU: 0
[0001.386] Interrupts Init done
[0001.389] calling constructors
[0001.392] initializing heap
[0001.395] I> Heap: [0xa06905a8 ... 0xab000000]
[0001.399] initializing threads
[0001.402] initializing timers
[0001.405] creating bootstrap completion thread
[0001.409] top of bootstrap2()
[0001.412] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.416] initializing platform
[0001.419] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.425] W> device prod register failed
[0001.429] I> Bl_dtb @0xaaf00000
[0001.434] W> "plugin-manager" doesn't exist, creating
[0001.437] W> "ids" doesn't exist, creating
[0001.441] W> "connection" doesn't exist, creating
[0001.445] W> "configs" doesn't exist, creating
[0001.456] I> Find /i2c@3160000's alias i2c0
[0001.456] I> Reading eeprom i2c=0 address=0x50
[0001.483] I> Device at /i2c@3160000:0x50
[0001.483] I> Reading eeprom i2c=0 address=0x57
[0001.484] E> I2C: slave not found in slaves.
[0001.484] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.485] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.485] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0001.493] E> eeprom: Failed to read I2C slave device
[0001.498] I> Eeprom read failed 0x3526070d
[0001.503] I> Find /i2c@c240000's alias i2c1
[0001.506] I> Reading eeprom i2c=1 address=0x50
[0001.511] E> I2C: slave not found in slaves.
[0001.514] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.522] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.527] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.537] E> eeprom: Retry to read I2C slave device.
[0001.542] E> I2C: slave not found in slaves.
[0001.546] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.554] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.559] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.569] E> eeprom: Failed to read I2C slave device
[0001.574] I> Eeprom read failed 0x3526070d
[0001.578] I> create_pm_ids: id: 3668-0000-200-H, len: 15
[0001.583] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.594] I> Adding plugin-manager/ids/3668-0000-200=/i2c@3160000:module@0x50
[0001.602] W> "i2c@3160000" doesn't exist, creating
[0001.606] W> "module@0x50" doesn't exist, creating
[0001.612] I> Adding plugin-manager/cvm
[0001.614] W> "chip-id" doesn't exist, creating
[0001.618] I> Adding plugin-manager/chip-id/A02P
[0001.622] I> Plugin-manager override starting
[0001.628] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.636] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.642] I> node /plugin-manager/fragement-tegra-sdhci-emmc-dis matches
[0001.649] I> Disable plugin-manager status in FDT
[0001.650] I> Plugin-manager override finished successfully
[0001.654] I> gpio framework initialized
[0001.660] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.667] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.673] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.681] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.689] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.695] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.701] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.708] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.716] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.723] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.730] I> fixed regulator driver initialized
[0001.737] I> register 'maxim' power off handle
[0001.738] I> virtual i2c enabled
[0001.741] I> registered 'maxim,max20024' pmic
[0001.745] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.751] I> Boot-device: QSPI
[0001.754] I> Boot_device: QSPI_FLASH instance: 0
[0001.759] I> QSPI source rate = 204000 Khz
[0001.763] I> Requested rate for QSPI clock = 34000 Khz
[0001.768] I> BPMP-set rate for QSPI clk = 34000 Khz
[0001.773] I> QSPI Flash Size = 32 MB
[0001.780] I> Qspi initialized successfully
[0001.781] I> qspi flash-0 params source = boot args
[0001.785] I> create_pm_ids: id: 3668-0000-200-H, len: 15
[0001.790] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.801] I> Found sdcard
[0001.805] I> enabling 'vdd-sdmmc1-sw' regulator
[0001.812] I> regulator 'vdd-sdmmc1-sw' already enabled
[0001.976] I> sdmmc SDR mode
[0001.990] I> -0 params source =
[0001.991] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.002] I> Found 11 partitions in SDCARD (instance 0)
[0002.011] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.014] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.015] I> hdmi cable connected
[0002.016] W> set volts not configured for 'vdd-1v0'
[0002.017] W> set volts not configured for 'vdd-1v8-hs'
[0002.020] E> invalid display type
[0002.021] E> cannot find any other nvdisp nodes
[0002.036] I> edid read success
[0002.049] I> edid read success
[0002.049] I> width = 640, height = 480, frequency = 25174825
[0002.050] I> width = 640, height = 480, frequency = 25174825
[0002.050] I> width = 1920, height = 1080, frequency = 148500000
[0002.054] I> width = 1920, height = 1080, frequency = 148500000
[0002.060] I> width = 1920, height = 540, frequency = 74250000
[0002.066] I> width = 1280, height = 720, frequency = 74175824
[0002.071] I> width = 1920, height = 1080, frequency = 148351648
[0002.077] I> width = 1280, height = 720, frequency = 74175824
[0002.083] I> width = 1920, height = 1080, frequency = 148351648
[0002.088] I> width = 1920, height = 1080, frequency = 74175824
[0002.094] I> width = 1920, height = 1080, frequency = 74175824
[0002.100] I> width = 1920, height = 1080, frequency = 74175824
[0002.105] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.115] I> hdmi_enable, starting HDMI initialisation
[0002.121] I> hdmi_enable, HDMI initialisation complete
[0002.131] I> Load in CBoot Boot Options partition and parse it
[0002.132] E> Error -9 when finding node with path /boot-configuration
[0002.134] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.141] I> Hit any key to stop autoboot: 4 3 2 1
[0004.149] initializing target
[0004.149] calling apps_init()
[0004.150] starting app kernel_boot_app
[0004.156] I> found decompressor handler: lz4-legacy
[0004.156] I> decompressing BMP blob ...
[0004.160] I> Kernel type = Normal
[0004.160] I> Loading kernel-bootctrl from partition
[0004.160] I> Loading partition kernel-bootctrl at 0xa4ab0000 from device(0x6)
[0004.187] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.188] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.188] I> ########## SD boot ##########
[0004.189] I> Found sdcard
[0004.190] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.193] I> regulator 'vdd-sdmmc1-sw' already enabled
[0004.228] I> sdmmc SDR mode
[0004.243] I> -0 params source =
[0004.243] I> Already published: 00060000
[0004.243] I> Look for boot partition
[0004.243] I> Fallback: assuming 0th partition is boot partition
[0004.244] I> Detect filesystem
[0004.266] I> Loading extlinux.conf ...
[0004.266] I> rootfs path: /sd/boot/extlinux/extlinux.conf
[0004.295] I> L4T boot options
[0004.295] I> [1]: "primary kernel"
[0004.295] I> Enter choice:
[0007.297] I> Continuing with default option: 1
[0007.297] I> Loading kernel sig file from rootfs ...
[0007.297] I> rootfs path: /sd/boot/Image.sig
[0007.311] I> Loading kernel binary from rootfs ...
[0007.311] I> rootfs path: /sd/boot/Image
[0010.133] I> Validate kernel ...
[0010.133] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0010.462] I> No kernel-dtb binary path
[0010.462] I> A/B: bin_type (38) slot 1
[0010.463] I> Loading kernel-dtb_b from partition
[0010.463] I> Loading partition kernel-dtb_b at 0x91000000 from device(0x6)
[0010.506] I> Validate kernel-dtb ...
[0010.507] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0010.510] I> Loading ramdisk from rootfs ...
[0010.510] I> rootfs path: /sd/boot/initrd
[0010.973] I> Kernel hdr @0xa4ab0000
[0010.973] I> Kernel dtb @0x90000000
[0010.973] I> decompressor handler not found
[0010.974] I> Copying kernel image (34330640 bytes) from 0xa4ab0000 to 0x80080000 ... [0010.984] I> Done
[0010.985] I> Updated bpmp info to DTB
[0010.986] I> Ramdisk: Base: 0x92000000; Size: 0x54ecaf
[0010.986] I> Updated initrd info to DTB
[0010.986] W> WARN: Fail to override "console=none" in commandline
[0010.987] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0010.993] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0011.000] I> Active slot suffix: _b
[0011.004] I> add_boot_slot_suffix: slot_suffix = _b
[0011.008] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa069b000 lut_mem=0x2008@0xa0697000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix=_b boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0011.038] I> Updated bootarg info to DTB
[0011.042] W> MAC addr invalid!
[0011.045] E> Failed to get WIFI MAC address
[0011.049] W> MAC addr invalid!
[0011.052] E> Failed to get Bluetooth MAC address
[0011.056] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:07:81:ab
[0011.063] W> "plugin-manager" doesn't exist, creating
[0011.067] I> Adding /chosen/plugin-manager/cvm
[0011.071] W> "chip-id" doesn't exist, creating
[0011.076] I> Adding /chosen/plugin-manager/chip-id
[0011.080] W> "configs" doesn't exist, creating
[0011.085] I> Adding /chosen/plugin-manager/configs
[0011.089] W> "ids" doesn't exist, creating
[0011.093] I> Adding /chosen/plugin-manager/ids
[0011.098] W> "odm-data" doesn't exist, creating
[0011.102] I> Adding /chosen/plugin-manager/odm-data
[0011.109] W> "memory" doesn't exist, creating
[0011.111] I> [0] START: 0x80000000, END: 0xac000000
[0011.115] I> [1] START: 0xac004000, END: 0xf09d0000
[0011.120] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0011.125] I> dram_block larger than 80000000
[0011.129] I> [3] START: 0x100000000, END: 0x280000000
[0011.134] I> added [base:0x80000000, size:0x2c000000] to /memory
[0011.140] I> added [base:0xac200000, size:0x44600000] to /memory
[0011.146] I> added [base:0x100000000, size:0x180000000] to /memory
[0011.152] I> Updated memory info to DTB
[0011.156] E> add_disp_param: failed to get display params for du=1
[0011.162] W> "reset" doesn't exist, creating
[0011.166] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0011.170] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0011.175] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0011.180] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0011.184] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0011.189] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0011.194] I> Deleted cpu@6 node in DT
[0011.197] I> Deleted cpu@7 node in DT
[0011.201] I> Deleted cluster3 node in FDT
[0011.205] I> Update arm-pmu in FDT
[0011.208] I> - update property: interrupts
[0011.212] I> - update property: interrupt-affinity
[0011.217] W> "misc-data" doesn't exist, creating
[0011.221] I> Boot-device: QSPI
[0011.224] W> Unknown boot device
[0011.227] I> Add storage-qspi to plugin-manager/misc-data
[0011.232] W> Unknown storage device
[0011.236] I> Add serial number:1421520055922 as DT property
[0011.242] I> Plugin-manager override starting
[0011.246] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0011.252] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0011.259] I> node /plugin-manager/fragement-tegra-sdhci-emmc-dis matches
[0011.265] I> Disable plugin-manager status in FDT
[0011.268] I> Plugin-manager override finished successfully
[0011.273] I> tegrabl_load_kernel_and_dtb: Done
[0011.296] I> QSPI: erasing sectors from 176 - 176
[0011.296] I> QSPI: recoverying tail blocks from 22536 - 22656
[0011.909] I> QSPI: erasing sectors from 177 - 177
[0011.909] I> QSPI: recoverying tail blocks from 22664 - 22784
[0012.552] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3357) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Thu Jun 25 21:22:12 PDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44600000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a069b000
[ 0.000000] Found lut_mem: 00002008@a0697000
▒▒WARNING: at platform/drivers/pg/pg-cv-t194.c:73
WARNING: pll_d2 has no dyn ramp
▒▒[ 4.694950] tegra_cec 3960000.tegra_cec: timeout in tegra_cec_native_write_l:172.
[ 12.118946] tegra-i2c 3180000.i2c: pio timed out addr: 0x10 tlen:28 rlen:4
[ 12.119195] tegra-i2c 3180000.i2c: --- register dump for debugging ----
[ 12.119381] tegra-i2c 3180000.i2c: I2C_CNFG - 0x22c00
[ 12.119554] tegra-i2c 3180000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 12.119736] tegra-i2c 3180000.i2c: I2C_FIFO_CONTROL - 0x0
[ 12.119903] tegra-i2c 3180000.i2c: I2C_FIFO_STATUS - 0x800080
[ 12.120063] tegra-i2c 3180000.i2c: I2C_MST_FIFO_CONTROL - 0x70000
[ 12.120254] tegra-i2c 3180000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 12.120425] tegra-i2c 3180000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 12.120625] tegra-i2c 3180000.i2c: I2C_INT_MASK - 0x7d
[ 12.120769] tegra-i2c 3180000.i2c: I2C_INT_STATUS - 0x2
[ 12.120941] tegra-i2c 3180000.i2c: i2c transfer timed out addr: 0x10
[ 12.121172] imx219 9-0010: imx219_board_setup: error during i2c read probe (-110)
[ 12.121472] imx219 9-0010: board setup failed
[ 22.358991] tegra-i2c 3180000.i2c: timed out for bus clear
[ 22.359245] imx219 10-0010: imx219_board_setup: error during i2c read probe (-110)
[ 22.359512] imx219 10-0010: board setup failed
▒▒WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
▒▒[ 24.702201] cgroup: cgroup2: unknown option "nsdelegate"
▒▒[ 26.307381] random: crng init done
[ 26.307543] random: 7 urandom warning(s) missed due to ratelimiting
[ 26.835237] using random self ethernet address
[ 26.835443] using random host ethernet address
▒▒[ 28.062290] using random self ethernet address
[ 28.062298] using random host ethernet address
Ubuntu 18.04.4 LTS nvidia ttyTCU0
nvidia login: nvidia
Password:
Last login: 五 8月 28 17:28:08 CST 2020 on ttyTCU0
Welcome to Ubuntu 18.04.4 LTS (GNU/Linux 4.9.140-tegra aarch64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the 'unminimize' command.
71 packages can be updated.
0 updates are security updates.
nvidia@nvidia:~$ dmesg --follow
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 2030589
[ 0.000000] DMA zone: 7152 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 457725 pages, LIFO batch:31
[ 0.000000] Normal zone: 24576 pages used for memmap
[ 0.000000] Normal zone: 1572864 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1ffd04000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1998861
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa069b000 lut_mem=0x2008@0xa0697000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix=_b boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29176(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7182184K/8122356K available (15294K kernel code, 2934K rwdata, 6640K rodata, 8576K init, 609K bss, 186508K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13d808 ( 2935 KB)
[ 0.000000] .bss : 0xffffff800a13d808 - 0xffffff800a1d5f7c ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf08000000 ( 128 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000591] Console: colour dummy device 80x25
[ 0.000602] console [tty0] enabled
[ 0.000610] bootconsole [tegra_comb_uart0] disabled
[ 0.000623] kmemleak: Kernel memory leak detector disabled
[ 0.000642] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000658] pid_max: default: 32768 minimum: 301
[ 0.001741] Security Framework initialized
[ 0.002340] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002350] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.004018] ftrace: allocating 47104 entries in 185 pages
[ 0.394315] sched-energy: Sched-energy-costs installed from DT
[ 0.394334] ASID allocator initialised with 65536 entries
[ 0.429530] tegra-id: chipid=21917.
[ 0.429543] tegra-id: opt_subrevision=1.
[ 0.429569] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.429600] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.429610] DTB Build time: Jun 25 2020 21:27:47
[ 0.477743] CPU1: Booted secondary processor [4e0f0040]
[ 0.509887] CPU2: Booted secondary processor [4e0f0040]
[ 0.541947] CPU3: Booted secondary processor [4e0f0040]
[ 0.574233] CPU4: Booted secondary processor [4e0f0040]
[ 0.606258] CPU5: Booted secondary processor [4e0f0040]
[ 0.606448] Brought up 6 CPUs
[ 0.606489] SMP: Total of 6 processors activated.
[ 0.606512] CPU features: detected feature: Privileged Access Never
[ 0.606521] CPU features: detected feature: LSE atomic instructions
[ 0.606530] CPU features: detected feature: User Access Override
[ 0.606540] CPU features: detected feature: 32-bit EL0 Support
[ 0.607945] CPU: All CPU(s) started at EL2
[ 0.607997] alternatives: patching kernel code
[ 0.614525] devtmpfs: initialized
[ 0.657553] Initilizing CustomIPI irq domain
[ 0.657902] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.657918] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.671057] pinctrl core: initialized pinctrl subsystem
[ 0.671319] OS set in device tree is not L4T.
[ 0.671616] regulator-dummy: no parameters
[ 0.671897] Initializing plugin-manager
[ 0.671947] Plugin module not found
[ 0.671997] Plugin-manager status disabled
[ 0.673279] NET: Registered protocol family 16
[ 0.674676] pstore: using zlib compression
[ 0.674698] console [pstore-1] enabled
[ 0.674703] pstore: Registered ramoops as persistent store backend
[ 0.674709] ramoops: attached 0x200000@0xf0600000, ecc: 0/0
[ 0.692905] cpuidle: using governor menu
[ 0.694033] bpmp: waiting for handshake
[ 0.694040] bpmp: handshake completed
[ 0.694053] bpmp: synchronizing channels
[ 0.694062] bpmp: channels synchronized
[ 0.694068] bpmp: mail init ok
[ 0.696706] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.696927] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.696934] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.696940] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.696946] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.696953] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.696986] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.696993] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.697000] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.697007] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.697013] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.700570] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[ 0.700594] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.703139] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.705401] tegra_aon_clk_init: ok
[ 0.705411] Registering BPMP clocks...
[ 0.705507] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.706316] Serial: AMBA PL011 UART driver
[ 0.706511] tegra_powergate_init: DONE
[ 0.706596] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.706614] DTB Build time: Jun 25 2020 21:27:47
[ 0.709953] Tegra reboot handler registered.
[ 0.719029] iommu: Adding device 14160000.pcie to group 0
[ 0.719722] iommu: Adding device 141a0000.pcie to group 1
[ 0.721156] iommu: Adding device 2490000.ether_qos to group 2
[ 0.721710] iommu: Adding device 3100000.serial to group 3
[ 0.722245] iommu: Adding device 3110000.serial to group 4
[ 0.722678] iommu: Adding device 3140000.serial to group 5
[ 0.723365] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.723767] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.723791] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.723799] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.723807] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.723873] tegra-pmc: PMC Prod config success
[ 0.724138] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.724152] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.724530] iommu: Adding device 3400000.sdhci to group 6
[ 0.725122] iommu: Adding device 3210000.spi to group 7
[ 0.725603] iommu: Adding device 3230000.spi to group 8
[ 0.726021] iommu: Adding device 3270000.spi to group 9
[ 0.727447] iommu: Adding device 3160000.i2c to group 10
[ 0.727909] iommu: Adding device c240000.i2c to group 11
[ 0.728627] iommu: Adding device 3180000.i2c to group 12
[ 0.729116] iommu: Adding device 3190000.i2c to group 13
[ 0.729738] iommu: Adding device 31b0000.i2c to group 14
[ 0.730186] iommu: Adding device 31c0000.i2c to group 15
[ 0.730679] iommu: Adding device c250000.i2c to group 16
[ 0.731156] iommu: Adding device 31e0000.i2c to group 17
[ 0.731803] iommu: Adding device sound to group 18
[ 0.732406] iommu: Adding device 3510000.hda to group 19
[ 0.733007] iommu: Adding device bc00000.rtcpu to group 20
[ 0.734912] iommu: Adding device 13e10000.host1x to group 21
[ 0.735348] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.735807] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.736208] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.736668] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.737145] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.737547] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.738086] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.738576] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.739123] iommu: Adding device 15340000.vic to group 30
[ 0.739649] iommu: Adding device 15380000.nvjpg to group 31
[ 0.739981] iommu: Adding device 15500000.tsec to group 32
[ 0.740461] iommu: Adding device 15100000.tsecb to group 33
[ 0.740917] iommu: Adding device 15480000.nvdec to group 34
[ 0.741289] iommu: Adding device 15140000.nvdec1 to group 35
[ 0.741683] iommu: Adding device 154c0000.nvenc to group 36
[ 0.742020] iommu: Adding device 15a80000.nvenc1 to group 37
[ 0.742507] iommu: Adding device 15880000.nvdla0 to group 38
[ 0.743036] iommu: Adding device 158c0000.nvdla1 to group 39
[ 0.743729] iommu: Adding device 15200000.nvdisplay to group 40
[ 0.743922] platform 15200000.nvdisplay: IOVA linear map 0x00000000a069b000(800000)
[ 0.743936] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0697000(3000)
[ 0.747969] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.748068] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.748849] iommu: Adding device 15210000.nvdisplay to group 41
[ 0.748905] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.751559] iommu: Adding device 15c10000.vi to group 42
[ 0.751729] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.752256] iommu: Adding device 14800000.isp to group 43
[ 0.753401] iommu: Adding device 16000000.pva0 to group 44
[ 0.754034] iommu: Adding device 16800000.pva1 to group 45
[ 0.754499] iommu: Adding device 15810000.se to group 46
[ 0.755000] iommu: Adding device 15820000.se to group 47
[ 0.755369] iommu: Adding device 15830000.se to group 48
[ 0.755733] iommu: Adding device 15840000.se to group 49
[ 0.756124] iommu: Adding device c1a0000.aon to group 50
[ 0.758156] iommu: Adding device d000000.bpmp to group 51
[ 0.758531] bpmp: ping status is 0
[ 0.758660] bpmp d000000.bpmp: firmware tag is 57f8a77779f848bf2ecf21dabee5645f
[ 0.761869] bpmp d000000.bpmp: probe ok
[ 0.763552] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.764085] iommu: Adding device smmu_test to group 52
[ 0.765361] mc: mapped MMIO address: 0xffffff800a590000 -> 0x2c10000
[ 0.765386] mc: mapped MMIO address: 0xffffff800a5b0000 -> 0x2c20000
[ 0.765407] mc: mapped MMIO address: 0xffffff800a5d0000 -> 0x2c30000
[ 0.765428] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c40000
[ 0.765448] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c50000
[ 0.765470] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2b80000
[ 0.765490] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2b90000
[ 0.765511] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2ba0000
[ 0.765532] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2bb0000
[ 0.765551] mc: mapped MMIO address: 0xffffff800b090000 -> 0x1700000
[ 0.765571] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x1710000
[ 0.765590] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1720000
[ 0.765624] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1730000
[ 0.765648] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1740000
[ 0.765666] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1750000
[ 0.765683] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1760000
[ 0.765700] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1770000
[ 0.765778] mc-err: mcerr ops are set to t19x
[ 0.772862] iommu: Adding device 2600000.dma to group 53
[ 0.779705] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[ 0.780979] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.781022] GPIO line 412 (camera-control-output-low) hogged as output/low
[ 0.781059] GPIO line 413 (camera-control-output-low) hogged as output/low
[ 0.781435] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.792126] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[ 0.792192] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.792231] GPIO line 266 (w-disable1) hogged as output/high
[ 0.792264] GPIO line 264 (w-disable2) hogged as output/high
[ 0.792613] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.795741] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.795751] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.796594] iommu: Adding device 3550000.xudc to group 54
[ 0.797500] iommu: Adding device 3610000.xhci to group 55
[ 0.800001] arm64_ras arm64_ras: probed
[ 0.800501] ras_fhi_enable: FHI 468 enabled on CPU0
[ 0.800552] ras_fhi_enable: FHI 469 enabled on CPU1
[ 0.800639] ras_fhi_enable: FHI 470 enabled on CPU2
[ 0.800724] ras_fhi_enable: FHI 471 enabled on CPU3
[ 0.800824] ras_fhi_enable: FHI 472 enabled on CPU4
[ 0.800908] ras_fhi_enable: FHI 473 enabled on CPU5
[ 0.801105] carmel_ras_enable: RAS enabled on cpu0
[ 0.801282] carmel_ras_enable: RAS enabled on cpu1
[ 0.801539] carmel_ras_enable: RAS enabled on cpu2
[ 0.801799] carmel_ras_enable: RAS enabled on cpu3
[ 0.802017] carmel_ras_enable: RAS enabled on cpu4
[ 0.802221] carmel_ras_enable: RAS enabled on cpu5
[ 0.802310] carmel_ras carmel_ras: probed
[ 0.803626] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 477, noc_nonsecure_irq = 476>
[ 0.804193] tegra-cbb c600000.aon-noc: noc_secure_irq = 479, noc_nonsecure_irq = 478>
[ 0.805362] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 481, noc_nonsecure_irq = 480>
[ 0.806473] tegra-cbb be00000.rce-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[ 0.807462] tegra-cbb b600000.sce-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[ 0.807981] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.809580] vdd-ac-bat: 5000 mV
[ 0.810120] vdd-sdmmc1-sw: 3300 mV
[ 0.810517] vdd-1v8-sd: 1800 mV
[ 0.810912] vdd-3v3-cvb: 3300 mV
[ 0.811299] vdd-1v8-cvb: 1800 mV
[ 0.811769] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.811814] vdd-epb-1v0: 1000 mV
[ 0.812274] avdd-cam-2v8: 2800 mV
[ 0.812720] vdd-fan: 5000 mV
[ 0.813152] vdd-hdmi-5v0: 5000 mV
[ 0.813636] vdd_sys_en: 1200 mV
[ 0.844804] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.849963] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.850338] SCSI subsystem initialized
[ 0.850596] libata version 3.00 loaded.
[ 0.850896] usbcore: registered new interface driver usbfs
[ 0.850964] usbcore: registered new interface driver hub
[ 0.851091] usbcore: registered new device driver usb
[ 0.863440] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.866380] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 0.874308] vdd-1v0: at 1000 mV
[ 0.878343] vdd-1v8-hs: at 1800 mV
[ 0.882396] vdd-1v8-ls: at 1800 mV
[ 0.886389] vdd-1v8-ao: at 1800 mV
[ 0.894434] vddio-ddr-1v1: at 1100 mV
[ 0.902207] vdd-rtc: at 800 mV
[ 0.903507] spmic-ldo1: at 2375 mV
[ 0.914251] vdd-ao-3v3: at 3300 mV
[ 0.922323] vddio-emmc-3v3: at 3300 mV
[ 0.923642] spmic-ldo4: at 1587 mV
[ 0.934339] vdd-usb-3v3: at 3300 mV
[ 0.942388] vddio-sdmmc1-3v3: at 3300 mV
[ 0.946389] vdd-csi-1v2: at 1200 mV
[ 0.947875] spmic-ldo8: at 1800 mV
[ 0.952933] GPIO line 246 (gpio_default) hogged as output/high
[ 0.954317] GPIO line 247 (gpio_default) hogged as output/high
[ 0.954708] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.955048] max77620 4-003c: max77620 probe successful
[ 0.955487] media: Linux media interface: v0.10
[ 0.955546] Linux video capture interface: v2.00
[ 0.956922] pps_core: LinuxPPS API ver. 1 registered
[ 0.956931] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.956955] PTP clock support registered
[ 0.957212] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.957498] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.957533] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.960169] trusty trusty: trusty version: Built: 21:16:17 Jun 25 2020
[ 0.960236] trusty trusty: selected api version: 3 (requested 3)
[ 0.961358] Advanced Linux Sound Architecture Driver Initialized.
[ 0.961953] Bluetooth: Core ver 2.22
[ 0.961994] NET: Registered protocol family 31
[ 0.962000] Bluetooth: HCI device and connection manager initialized
[ 0.962012] Bluetooth: HCI socket layer initialized
[ 0.962021] Bluetooth: L2CAP socket layer initialized
[ 0.962073] Bluetooth: SCO socket layer initialized
[ 0.964540] camchar: rtcpu character device driver loaded
[ 0.965040] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 0.965155] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.966877] clocksource: Switched to clocksource arch_sys_counter
[ 1.018532] VFS: Disk quotas dquot_6.6.0
[ 1.018643] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.019195] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.020590] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.020638] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 1.020949] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 1.020961] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 1.020974] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.020982] nvmap_page_pool_init: Total RAM pages: 1983962
[ 1.020994] nvmap_page_pool_init: nvmap page pool size: 247995 pages (968 MB)
[ 1.021152] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.021653] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 1.024475] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.039681] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.040056] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.040391] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.040618] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.040849] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.042125] la/ptsa driver initialized.
[ 1.042563] NET: Registered protocol family 2
[ 1.043556] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.043848] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.044449] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.044498] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.044649] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.045181] NET: Registered protocol family 1
[ 1.045876] RPC: Registered named UNIX socket transport module.
[ 1.045883] RPC: Registered udp transport module.
[ 1.045888] RPC: Registered tcp transport module.
[ 1.045893] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.045904] PCI: CLS 0 bytes, default 64
[ 1.046105] Trying to unpack rootfs image as initramfs...
[ 1.232127] Freeing initrd memory: 5432K
[ 1.254780] random: fast init done
[ 1.259448] host1x 13e10000.host1x: initialized
[ 1.261764] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.266424] audit: initializing netlink subsys (disabled)
[ 1.266474] audit: type=2000 audit(0.888:1): initialized
[ 1.267424] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.280126] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.281715] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.282579] 9p: Installing v9fs 9p2000 file system support
[ 1.288590] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.288786] io scheduler noop registered
[ 1.289078] io scheduler cfq registered (default)
[ 1.292557] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.323070] iommu: Adding device 2993000.adsp to group 56
[ 1.435309] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[ 1.436140] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.449143] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.449601] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.450232] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.450708] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.451175] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.454499] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.454758] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.457868] tsec 15500000.tsec: initialized
[ 1.459657] tsec 15100000.tsecb: initialized
[ 1.463390] nvdec 15480000.nvdec: initialized
[ 1.466175] nvdec 15140000.nvdec1: initialized
[ 1.471854] falcon 15340000.vic: initialized
[ 1.473649] falcon 15380000.nvjpg: initialized
[ 1.475705] falcon 154c0000.nvenc: initialized
[ 1.477756] falcon 15a80000.nvenc1: initialized
[ 1.481630] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.483353] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.484710] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.486105] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.487514] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.488918] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.490338] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.491780] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.495147] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.500329] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.500768] scare-pigeon 14b00000.isp-thi: initialized
[ 1.506531] pva 16000000.pva0: initialized
[ 1.512342] pva 16800000.pva1: initialized
[ 1.517402] nvdla 15880000.nvdla0: initialized
[ 1.522216] nvdla 158c0000.nvdla1: initialized
[ 1.523736] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.523748] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.523786] tegradccommon 15200000.dc_common: dma mapping done
[ 1.523929] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[ 1.523939] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.524237] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.524275] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.524595] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.524605] tegra_cec 3960000.tegra_cec: probed
[ 1.525258] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.525319] generic_infoframe_type: 0x87
[ 1.525409] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.525440] tegradc 15200000.nvdisplay: Display dc.ffffff800bd10000 registered with id=0
[ 1.529886] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 7088400 KB/s
[ 1.529896] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 800000000 Hz
[ 1.529902] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 1.530216] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.530248] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.531266] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.536730] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.537461] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.537470] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.537765] kfuse 3830000.kfuse: initialized
[ 1.537964] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.537972] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.542563] tegradc 15200000.nvdisplay: probed
[ 1.544960] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.547558] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.548765] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.549585] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 1.550981] console [ttyTCU0] enabled
[ 1.551305] [drm] Initialized
[ 1.566571] brd: module loaded
[ 1.573481] loop: module loaded
[ 1.573586] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.573723] tegra_profiler: auth: init
[ 1.574392] THERMAL EST: found 3 subdevs
[ 1.574400] THERMAL EST num_resources: 0
[ 1.574406] [THERMAL EST subdev 0]
[ 1.574413] [THERMAL EST subdev 1]
[ 1.574419] [THERMAL EST subdev 2]
[ 1.574430] THERMAL EST: Found 2 profiles, default profile is quiet
[ 1.574901] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.574909] THERMAL EST: thz register success.
[ 1.575206] THERMAL EST: end of probe, return err: 0
[ 1.575982] sd: No Scsi addr parsed to reserve index
[ 1.576025] hisi_sas: driver version v1.6
[ 1.586394] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 1.586413] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 1.586441] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 1.586673] 1 ofpart partitions found on MTD device spi6.0
[ 1.586690] Creating 1 MTD partitions on "spi6.0":
[ 1.586701] 0x000000000000-0x000002000000 : "Whole_flash0"
[ 1.589160] libphy: Fixed MDIO Bus: probed
[ 1.589767] tun: Universal TUN/TAP device driver, 1.6
[ 1.589772] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.590592] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.590598] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.590647] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.590652] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.590703] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.590713] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.590760] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.590765] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.593910] Console: switching to colour frame buffer device 240x67
[ 1.594022] tegradc 15200000.nvdisplay: fb registered
[ 1.594261] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 1.594821] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.594937] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.596977] Parent Clock set for DC plld2
[ 1.648851] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 1.649488] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 1.649501] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 1.675126] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.675133] Extcon AUX1(HDMI) enable
[ 1.675704] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.675736] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.675812] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.675860] tegradc 15210000.nvdisplay: Display dc.ffffff800d150000 registered with id=1
[ 1.676079] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.676089] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.684383] tegradc 15210000.nvdisplay: probed
[ 1.684674] tegradc 15210000.nvdisplay: fb registered
[ 1.687943] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.687950] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.687962] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.687973] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.687987] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 1.688002] Extcon DP: HPD disabled
[ 1.688006] hpd: hpd_switch 0
[ 1.688012] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.688023] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.688033] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.810129] tegradc 15200000.nvdisplay: blank - powerdown
[ 1.834335] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 7 81 ab
[ 1.834492] libphy: dwc_phy: probed
[ 1.836835] PPP generic driver version 2.4.2
[ 1.837004] PPP BSD Compression module registered
[ 1.837010] PPP Deflate Compression module registered
[ 1.837032] PPP MPPE Compression module registered
[ 1.837038] NET: Registered protocol family 24
[ 1.837087] usbcore: registered new interface driver r8152
[ 1.837124] usbcore: registered new interface driver asix
[ 1.837156] usbcore: registered new interface driver ax88179_178a
[ 1.837182] usbcore: registered new interface driver cdc_ether
[ 1.837212] usbcore: registered new interface driver net1080
[ 1.837238] usbcore: registered new interface driver cdc_subset
[ 1.837267] usbcore: registered new interface driver zaurus
[ 1.837305] usbcore: registered new interface driver cdc_ncm
[ 1.837467] VFIO - User Level meta-driver version: 0.3
[ 1.839142] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.839168] ehci-pci: EHCI PCI platform driver
[ 1.839238] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.839254] ohci-pci: OHCI PCI platform driver
[ 1.839296] ohci-platform: OHCI generic platform driver
[ 1.844001] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 1.846045] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f5ae8c00 id
[ 1.846351] usbcore: registered new interface driver uas
[ 1.846402] usbcore: registered new interface driver usb-storage
[ 1.846520] usbcore: registered new interface driver usbserial
[ 1.849210] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1.849214] Extcon AUX1(HDMI) disable
[ 1.849319] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 1.849351] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.849371] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 1.850074] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 1.850125] tegra-xusb 3610000.xhci: irq 463, io mem 0x03610000
[ 1.850331] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.850343] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.850348] usb usb1: Product: xHCI Host Controller
[ 1.850352] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.850356] usb usb1: SerialNumber: 3610000.xhci
[ 1.850929] hub 1-0:1.0: USB hub found
[ 1.850975] hub 1-0:1.0: 4 ports detected
[ 1.851507] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.851519] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 1.851527] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.851813] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.851824] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.851829] usb usb2: Product: xHCI Host Controller
[ 1.851834] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.851838] usb usb2: SerialNumber: 3610000.xhci
[ 1.852683] hub 2-0:1.0: USB hub found
[ 1.852726] hub 2-0:1.0: 4 ports detected
[ 1.853013] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 1.853089] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.854114] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.854122] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 1.854147] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.854398] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.855052] mousedev: PS/2 mouse device common for all mice
[ 1.855145] usbcore: registered new interface driver xpad
[ 1.875766] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.877002] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1.897829] tegradc 15200000.nvdisplay: unblank
[ 1.899588] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.899839] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.908608] Parent Clock set for DC plld2
[ 1.913677] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 1.915077] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 1.915086] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.949690] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.949694] Extcon AUX1(HDMI) enable
[ 1.963717] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.965083] Wake73 for irq=42
[ 1.966480] rtc rtc1: alarm rtc device
[ 1.966495] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.966525] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.966723] i2c /dev entries driver
[ 1.969103] i2c i2c-2: Added multiplexed i2c bus 9
[ 1.969419] i2c i2c-2: Added multiplexed i2c bus 10
[ 1.969434] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 1.969860] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 2.178928] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.208104] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 2.208116] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.208121] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 2.208126] usb 1-2: Manufacturer: Generic
[ 2.209153] hub 1-2:1.0: USB hub found
[ 2.209742] hub 1-2:1.0: 4 ports detected
[ 2.330918] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 2.354725] usb 1-3: New USB device found, idVendor=046d, idProduct=c534
[ 2.354735] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.354741] usb 1-3: Product: USB Receiver
[ 2.354752] usb 1-3: Manufacturer: Logitech
[ 2.498930] usb 1-2.2: new high-speed USB device number 4 using tegra-xusb
[ 2.519507] usb 1-2.2: New USB device found, idVendor=0bda, idProduct=881a
[ 2.519516] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.519523] usb 1-2.2: Product: 802.11n NIC
[ 2.519551] usb 1-2.2: Manufacturer: Realtek
[ 2.519556] usb 1-2.2: SerialNumber: 123456
[ 2.550930] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 3.963666] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 3.963673] Extcon HDMI: HPD enabled
[ 3.963695] tegradc 15200000.nvdisplay: hdmi: plugged
[ 4.695220] tegra_cec 3960000.tegra_cec: Sent <Text View On> res: -62.
[ 4.695226] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 6.011470] Wake76 for irq=199
[ 6.011479] Wake77 for irq=199
[ 6.011484] Wake78 for irq=199
[ 6.011488] Wake79 for irq=199
[ 6.011493] Wake80 for irq=199
[ 6.011497] Wake81 for irq=199
[ 6.011502] Wake82 for irq=199
[ 6.011541] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 6.011549] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 6.339274] usb 2-3: new SuperSpeed USB device number 2 using tegra-xusb
[ 6.367913] usb 2-3: New USB device found, idVendor=0bda, idProduct=0411
[ 6.367924] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.367931] usb 2-3: Product: 4-Port USB 3.1 Hub
[ 6.367938] usb 2-3: Manufacturer: Generic
[ 6.373048] hub 2-3:1.0: USB hub found
[ 6.374269] hub 2-3:1.0: 4 ports detected
[ 6.663170] usb 2-3.1: new SuperSpeed USB device number 3 using tegra-xusb
[ 6.683950] usb 2-3.1: New USB device found, idVendor=0bda, idProduct=8153
[ 6.683960] usb 2-3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 6.683966] usb 2-3.1: Product: USB 10/100/1000 LAN
[ 6.683972] usb 2-3.1: Manufacturer: Realtek
[ 6.683978] usb 2-3.1: SerialNumber: 000000000000
[ 6.775371] usb 2-3.1: reset SuperSpeed USB device number 3 using tegra-xusb
[ 6.802456] r8152 2-3.1:1.0 eth1: v2.09.00 (2017/08/21)
[ 6.802464] r8152 2-3.1:1.0 eth1: This product is covered by one or more of the following patents:
US6,570,884, US6,115,776, and US6,327,625.
[ 12.121724] imx219: probe of 9-0010 failed with error -110
[ 12.122230] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 12.145453] tegra-i2c 3180000.i2c: arb lost in communicate to add 0x10
[ 22.359785] imx219: probe of 10-0010 failed with error -110
[ 22.361126] max77620-power max20024-power: Event recorder REG_NVERC : 0x54
[ 22.368231] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 22.372368] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 22.372397] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 22.372405] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 22.372550] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 22.372631] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 22.372641] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 22.372938] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 22.373004] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 22.373012] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 22.373305] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 22.373417] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 22.373425] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 22.373840] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 22.373956] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 22.373964] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 22.374359] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 22.374951] FAN dev name: pwm-fan
[ 22.375001] FAN:gpio request success.
[ 22.375012] FAN: can't find tach_gpio
[ 22.375024] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 22.375062] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 22.375316] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 22.375323] pwm_fan_driver pwm-fan: tach period: 1000
[ 22.375945] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 22.375973] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 22.375982] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 22.375990] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 22.375996] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 22.376004] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 22.376011] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 22.376018] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 22.376025] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 22.376032] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 22.377116] device-mapper: uevent: version 1.0.3
[ 22.377513] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 22.381366] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 22.382426] cpuidle: Initializing cpuidle driver
[ 22.383301] sdhci: Secure Digital Host Controller Interface driver
[ 22.383306] sdhci: Copyright(c) Pierre Ossman
[ 22.383310] sdhci-pltfm: SDHCI platform and OF driver helper
[ 22.383646] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 22.384394] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 22.386176] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 245
[ 22.390424] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 22.392066] tegra-se-nvhost 15810000.se: initialized
[ 22.393104] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 22.393757] tegra-se-nvhost 15820000.se: initialized
[ 22.394849] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 22.395557] tegra-se-nvhost 15830000.se: initialized
[ 22.396157] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 22.396743] tegra-se-nvhost 15840000.se: initialized
[ 22.397712] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 22.398020] hidraw: raw HID events driver (C) Jiri Kosina
[ 22.402246] input: Logitech USB Receiver as /devices/3610000.xhci/usb1/1-3/1-3:1.0/0003:046D:C534.0001/input/input0
[ 22.431034] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 22.431095] mmc0: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 22.459442] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-3/input0
[ 22.462897] input: Logitech USB Receiver as /devices/3610000.xhci/usb1/1-3/1-3:1.1/0003:046D:C534.0002/input/input1
[ 22.523237] hid-generic 0003:046D:C534.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-3/input1
[ 22.523306] usbcore: registered new interface driver usbhid
[ 22.523310] usbhid: USB HID core driver
[ 22.527767] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 22.528830] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 22.529295] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 22.529864] denver_knobs_init:MTS_VERSION:50168445
[ 22.530009] tegra19x_actmon d230000.actmon: in actmon_register()...
[ 22.530930] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 22.531321] t19x_cache tegra-cache: probed
[ 22.533311] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 22.533319] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 22.533863] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 22.534182] PLL_AON clock registered
[ 22.535472] Clocks initialized successfully
[ 22.536772] nvpmodel: initialized successfully
[ 22.537825] trusty-virtio trusty:virtio: initializing
[ 22.538068] trusty_ipc virtio0: vring0: va(pa) ffffffc1e2ba8000(0) qsz 32 notifyid 1
[ 22.538101] trusty_ipc virtio0: vring1: va(pa) ffffffc1e2baa000(0) qsz 32 notifyid 2
[ 22.538240] trusty-virtio trusty:virtio: initializing done
[ 22.538448] trusty_ipc virtio0: is online
[ 22.539033] usbcore: registered new interface driver snd-usb-audio
[ 22.540317] tegra-hda 3510000.hda: Override SDO lines to 4
[ 22.566936] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input2
[ 22.567124] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input3
[ 22.567328] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input4
[ 22.567533] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input5
[ 22.578280] OPE platform probe
[ 22.578437] OPE platform probe successful
[ 22.628013] mmc0: host does not support reading read-only switch, assuming write-enable
[ 22.682934] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 22.683066] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 22.683181] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 22.683295] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 22.683417] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 22.683531] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 22.683652] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 22.683780] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 22.683890] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 22.684012] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 22.684104] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 22.684193] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 22.684287] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 22.684376] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 22.684471] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 22.684560] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 22.684669] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 22.684786] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 22.684904] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 22.685025] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 22.716456] u32 classifier
[ 22.716465] Actions configured
[ 22.716559] Initializing XFRM netlink socket
[ 22.717145] NET: Registered protocol family 10
[ 22.717925] NET: Registered protocol family 17
[ 22.717943] NET: Registered protocol family 15
[ 22.717999] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 22.718090] Bluetooth: RFCOMM socket layer initialized
[ 22.718109] Bluetooth: RFCOMM ver 1.11
[ 22.718116] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 22.718130] Bluetooth: HIDP socket layer initialized
[ 22.718148] 9pnet: Installing 9P2000 support
[ 22.718205] Key type dns_resolver registered
[ 22.719220] Registered cp15_barrier emulation handler
[ 22.719245] Registered setend emulation handler
[ 22.720823] registered taskstats version 1
[ 22.721399] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 22.727790] OF: PCI: host bridge /pcie@14160000 ranges:
[ 22.727808] OF: PCI: IO 0x36100000..0x361fffff -> 0x36100000
[ 22.727817] OF: PCI: MEM 0x1740000000..0x17ffffffff -> 0x40000000
[ 22.727823] OF: PCI: MEM 0x1400000000..0x173fffffff -> 0x1400000000
[ 22.770132] mmc0: hw tuning done ...
[ 22.770168] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 22.770592] mmcblk0: mmc0:aaaa SC64G 59.5 GiB
[ 22.776579] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 23.242535] tegra-pcie-dw 14160000.pcie: link is down
[ 23.242681] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 23.242689] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 23.242696] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 23.242702] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 23.242707] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 23.242735] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 23.242916] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 23.243164] iommu: Adding device 0004:00:00.0 to group 58
[ 23.243385] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 23.243408] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 23.243617] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 23.243624] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 23.243718] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 23.243855] pcie_pme 0004:00:00.0:pcie001: unloading service driver pcie_pme
[ 23.243898] aer 0004:00:00.0:pcie002: unloading service driver aer
[ 23.243977] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 23.244044] iommu: Removing device 0004:00:00.0 from group 58
[ 23.244069] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 23.245641] tegra-pcie-dw 14160000.pcie: PCIe link is not up...!
[ 23.246602] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 23.247812] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 23.247829] OF: PCI: IO 0x3a100000..0x3a1fffff -> 0x3a100000
[ 23.247837] OF: PCI: MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[ 23.247843] OF: PCI: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 23.761620] tegra-pcie-dw 141a0000.pcie: link is down
[ 23.761816] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 23.761824] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 23.761832] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 23.761838] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 23.761843] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 23.761872] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 23.762004] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 23.762226] iommu: Adding device 0005:00:00.0 to group 58
[ 23.762550] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 23.762573] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 23.762801] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 23.762809] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 23.762936] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 23.763103] pcie_pme 0005:00:00.0:pcie001: unloading service driver pcie_pme
[ 23.763207] aer 0005:00:00.0:pcie002: unloading service driver aer
[ 23.763327] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 23.763442] iommu: Removing device 0005:00:00.0 from group 58
[ 23.763478] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 23.765658] tegra-pcie-dw 141a0000.pcie: PCIe link is not up...!
[ 23.776578] tegra-cbb 14040000.cv-noc: noc_secure_irq = 89, noc_nonsecure_irq = 88>
[ 23.781062] tegra194-isp5 14800000.isp: initialized
[ 23.788316] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 23.791064] tegra194-vi5 15c10000.vi: initialized
[ 23.796000] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--2 bound
[ 23.796070] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--1 bound
[ 23.796794] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 23.879785] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 23.880083] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 23.880278] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 23.880489] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 23.880919] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 23.880997] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 23.881219] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[ 23.881224] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 23.882346] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[ 23.882776] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 23.882908] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 23.883082] input: gpio-keys as /devices/gpio-keys/input/input6
[ 23.916135] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-02 03:00:26 UTC (946782026)
[ 23.916577] mmcblk mmc0:aaaa: Card claimed for testing.
[ 23.961073] bpmp: mounted debugfs mirror
[ 23.966994] vdd-1v8-sd: disabling
[ 23.967002] vdd-1v8-cvb: disabling
[ 23.967006] vdd-epb-1v0: disabling
[ 23.967012] avdd-cam-2v8: disabling
[ 23.967016] vdd-fan: disabling
[ 23.967020] vdd_sys_en: disabling
[ 23.967027] ALSA device list:
[ 23.967033] #0: tegra-hda-xnx at 0x3518000 irq 64
[ 23.967037] #1: jetson-xaviernx-ape
[ 23.969468] Freeing unused kernel memory: 8576K
[ 24.008830] Root device found: mmcblk0p1
[ 24.010273] Found dev node: /dev/mmcblk0p1
[ 24.431066] EXT4-fs (mmcblk0p1): 11 orphan inodes deleted
[ 24.431078] EXT4-fs (mmcblk0p1): recovery complete
[ 24.457490] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 24.458599] Rootfs mounted over mmcblk0p1
[ 24.483121] Switching from initrd to actual rootfs
[ 24.670669] systemd[1]: System time before build time, advancing clock.
[ 24.697777] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 24.720089] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 24.720784] systemd[1]: Detected architecture arm64.
[ 24.726463] systemd[1]: Set hostname to <nvidia>.
[ 24.864372] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 24.864390] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 25.030999] random: systemd: uninitialized urandom read (16 bytes read)
[ 25.031259] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 25.031358] random: systemd: uninitialized urandom read (16 bytes read)
[ 25.031386] systemd[1]: Reached target Swap.
[ 25.031435] random: systemd: uninitialized urandom read (16 bytes read)
[ 25.034672] systemd[1]: Created slice System Slice.
[ 25.035993] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 25.036291] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 25.115718] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 25.207155] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 25.462255] systemd-journald[2372]: Received request to flush runtime journal from PID 1
[ 27.796497] usbcore: registered new interface driver rtl8812au
[ 28.055791] Mass Storage Function, version: 2009/09/11
[ 28.055800] LUN: removable file: (no medium)
[ 28.343638] rndis0: HOST MAC b6:c7:c1:27:57:68
[ 28.343721] rndis0: MAC b6:c7:c1:27:57:69
[ 28.344347] usb0: HOST MAC b6:c7:c1:27:57:6a
[ 28.344379] usb0: MAC b6:c7:c1:27:57:6b
[ 28.344398] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 28.345073] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 28.345088] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 28.345879] tegra-xudc-new 3550000.xudc: entering ELPG
[ 28.346265] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 28.350601] l4tbr0: port 1(rndis0) entered blocking state
[ 28.350605] l4tbr0: port 1(rndis0) entered disabled state
[ 28.351169] device rndis0 entered promiscuous mode
[ 28.357533] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 28.362712] l4tbr0: port 2(usb0) entered blocking state
[ 28.362718] l4tbr0: port 2(usb0) entered disabled state
[ 28.363038] device usb0 entered promiscuous mode
[ 28.368932] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 28.559970] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 28.875801] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 28.883159] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 28.894431] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 28.958522] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 29.019247] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 29.217189] zram: Added device: zram0
[ 29.220810] zram: Added device: zram1
[ 29.226643] zram: Added device: zram2
[ 29.228844] zram: Added device: zram3
[ 29.230069] zram: Added device: zram4
[ 29.231783] zram: Added device: zram5
[ 29.253634] zram0: detected capacity change from 0 to 678387712
[ 29.287058] Adding 662484k swap on /dev/zram0. Priority:5 extents:1 across:662484k SS
[ 29.292260] zram1: detected capacity change from 0 to 678387712
[ 29.311348] Adding 662484k swap on /dev/zram1. Priority:5 extents:1 across:662484k SS
[ 29.313956] zram2: detected capacity change from 0 to 678387712
[ 29.337563] Adding 662484k swap on /dev/zram2. Priority:5 extents:1 across:662484k SS
[ 29.343918] zram3: detected capacity change from 0 to 678387712
[ 29.361470] Adding 662484k swap on /dev/zram3. Priority:5 extents:1 across:662484k SS
[ 29.368345] zram4: detected capacity change from 0 to 678387712
[ 29.397180] Adding 662484k swap on /dev/zram4. Priority:5 extents:1 across:662484k SS
[ 29.406207] zram5: detected capacity change from 0 to 678387712
[ 29.435593] Adding 662484k swap on /dev/zram5. Priority:5 extents:1 across:662484k SS
[ 29.570086] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 29.663078] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 31.562159] tegradc 15200000.nvdisplay: unblank
[ 31.562179] tegradc 15210000.nvdisplay: blank - powerdown
[ 36.869097] fuse init (API version 7.26)
[ 37.020817] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 37.020834] Bluetooth: BNEP socket layer initialized
[ 38.510778] tegradc 15200000.nvdisplay: unblank
[ 38.510793] tegradc 15210000.nvdisplay: blank - powerdown
Step 2
I log in my board via a HDMI monitor(connector to my carrier board),and run the samplevolumeFiltering
,there is no more logs print,then i run the second samplevolumeFiltering
,the board shutdown now,there is no logs printed. -
Step 3
I repower the carrier board and get the following logs via serial console frome my PC:
log.txt (28.8 KB)
