Trying to set up a brand new Jetson Orin AGX. Hooked up the Jetson to a Samsung monitor using a display port to hdmi cable, unit powers on but has no display. Tried also with a display port to display port cable on the same monitor since it supports both DP and HDMI but no luck. Any ideas ?
Please flash your Orin devkit with the SDK manager JetPack, be sure have a host PC with Ubuntu 20.04 to do the installation:
I have the same problem. I thought it was supposed to work out of the box but i’ll try flashing and report back
Reflashing the box did the trick
Same !
