I am using an Orin developer kit and the back USB A ports (next to the display port) are not working. I have tried monitoring dmesg --follow
when plugging in a device and there is no change in the kernel log. Additionally, the USB ports are not providing power to any devices. I have tried a keyboard, mouse, and usb to etherenet adapter. All of these devices are working on the front two usb ports. I have also tried to reflash to the unit and it is currently running Jetpack 5.1 but the usb ports are still not functioning.
Please share the information for reference:
$ cat /etc/nv_boot_control.conf
And please try Jetpack 5.0.2. If you hit the issue in both 5.0.2 and 5.1, probably it is an issue in hardware.
Hi:
Here are the results:
TNSPEC 3701-500-0000-J.0-1-1-jetson-agx-orin-devkit-
COMPATIBLE_SPEC 3701--0000--1--jetson-agx-orin-devkit-
TEGRA_LEGACY_UPDATE false
TEGRA_BOOT_STORAGE nvme0n1
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
The USB ports are also not working on 5.0.2.
