Hi,I meet the problem when I flashed Jetpack DP 6.0 on Jetson AGX Orin 64GB devkit.
My host PC: Dell laptop(not VM)
Host OS:Ubuntu 20.04
There is the sdkmanager exported log:
SDKM_logs_JetPack_6.0_DP_Linux_for_Jetson_AGX_Orin_modules_2024-01-30_17-59-34.zip (123.2 KB)
The Jetson AGX Orin 64GB devkit is in Force Recovry Mode,when i use lsusb command in terminal, the output is:
When i first meet this ERROR:might be timeout in USB write, i reference this topic.And i successfully flashed the jetpack 5.1.2 on orin 64GB devkit in Runtime(not pre-config) by my another host pc which installed ubuntu18.04.
Second,When I want flash Jetpack DP 6.0 by my laptop which installed ubuntu20.04, I meet the ERROR: might be timeout in USB write again.And In this time, i can’t flash jetpack 5.1.2 by my host pc which installed ubuntu18.04 because error: might be timeout in usb write.
Could you tell me how to figure this error?Thank you!
Best wish.
