ORIN NANO、ORIN NX、AGX ORIN搭配底板引出的HDMI,只有1080P分辨率,没有4K分辨率选项,是否正常?Jetson ORIN系列HDMI支持4K吗?谢谢。
Based on the provided context, I will provide a comprehensive answer to the question.
The question seems to be asking about the differences between Jetson Orin Nano, Orin NX, and AGX Orin, specifically in terms of HDMI support and resolution.
From the provided context, we can gather the following information:
- Jetson Orin Nano and Orin NX modules are supported by the Jetson Orin Nano reference carrier board (P3768-0000).
- Jetson AGX Orin modules are supported by the Jetson AGX Orin reference carrier board (P3737-0000).
- There is no explicit mention of HDMI support or resolution in the provided context. However, we can infer that the Jetson Orin Nano and Orin NX modules might have different HDMI capabilities compared to the Jetson AGX Orin modules.
To provide a more comprehensive answer, I would like to clarify that the Jetson Orin Nano and Orin NX modules are designed for different use cases and have different specifications. The Jetson Orin Nano is a more compact and power-efficient module, while the Orin NX is a more powerful module with higher performance capabilities.
Regarding HDMI support, the Jetson Orin Nano and Orin NX modules likely support HDMI 2.0, which can output up to 4K resolution at 60Hz. However, without explicit information, it’s difficult to confirm the exact HDMI capabilities of these modules.
In contrast, the Jetson AGX Orin modules are more powerful and might support higher resolutions, such as 4K at 120Hz or even 8K. However, without more information, it’s difficult to confirm the exact HDMI capabilities of these modules.
In summary, while we can’t provide an exact answer to the question without more information, we can infer that the Jetson Orin Nano, Orin NX, and AGX Orin modules have different specifications and capabilities, including potentially different HDMI support and resolution.
支持4k.
沒看到>1080p解析度的原因多半是你沒有設定DCB image進HDMI mode.
所以還在使用DP mode
您好!DP mode是否比HDMI mode 兼容性强,分辨率范围大?
您好,这个具体需要怎么改?有参考文档吗?谢谢
您好,这个具体要如何更改,有指导说明吗?谢谢。
Some posts here:
or you could check p3509-p3767 board config in your BSP. That config is the default one that uses HDMI mode.
