Thanks in advance for your support. Here is my setup :
- Jetson Nano Orin
- Ubuntu 20.04 installed in Jetson
- Linux jetsonorin-desktop 5.10.104-tegra
- I worked in Windows machine using VS code and compile in Jetson
- Toolkit Cuda 12
I have used this command : sudo reboot (as in Raspberry Pi) on Jetson and it goes down. After reboot, I have kernel errors, and the all ports are not working (display port, Ethernet); the USB port works only during the boot mode.
Using Port COM4 on Windows, I can access to jetson but can not do more because the Ethernet is not working ( so no IP address).
Here the log after boot and the login
Any help would be very useful !
Thanks;
log_kernel.txt (58.9 KB)
