I keep getting error code 11 and ECID errors when using the SDK Manager to flash. I am sure that I have entered Force Recovery Mode. As soon as the flashing starts, the USB connection to the Jetson Orin Nano gets interrupted, showing a flash failure, and then the USB reconnects. What should I do to resolve this?
Hi azfggrft20,
To help troubleshoot your issue, I need some additional information:
- Are you using a VM or a physical machine as your host?
- Is your host running Ubuntu 18.04 or Ubuntu 20.04?
For related requirement, please refer to the General Debug.
If your host machine meets the SDK requirements, please export the error log to us.
I was previously using a VM, and my Ubuntu version is 22.04. The JetPack version I want to install is 6.1.
Our SDK manager does not officially support virtual machines. We recommend using a physical machine and try flashing again.
