It is stuck at the logo screen after reset and does not move forward to the login page.
I am unable to install the SDK components onto the Jetson TX2 after flashing the OS. When I try to install the sdk components it gives me an error saying that "could not connect to the target device.
I have attached photos of the logo screen, error while installing sdk components and also the logs while installing sdk components.
00:49:04 INFO : null
00:49:15 INFO : CUDA on Host : download ‘CUDA on Host’ success
00:49:15 INFO : OpenCV on Host : download ‘OpenCV on Host’ success
00:49:15 INFO : VisionWorks on Host : download ‘VisionWorks on Host’ success
00:49:15 INFO : DevTools Documentation : download ‘DevTools Documentation’ success
00:49:15 INFO : CUDA Cross Compile Package on Host : download ‘CUDA Cross Compile Package on Host’ success
00:49:15 INFO : NVIDIA Nsight Systems : download ‘NVIDIA Nsight Systems’ success
00:49:15 INFO : NVIDIA Nsight Graphics : download ‘NVIDIA Nsight Graphics’ success
00:49:15 INFO : CUDA on Host : install ‘CUDA on Host’ success
00:49:15 INFO : OpenCV on Host : install ‘OpenCV on Host’ success
00:49:15 INFO : VisionWorks on Host : install ‘VisionWorks on Host’ success
00:49:15 INFO : DevTools Documentation : install ‘DevTools Documentation’ success
00:49:15 INFO : CUDA Cross Compile Package on Host : install ‘CUDA Cross Compile Package on Host’ success
00:49:15 INFO : NVIDIA Nsight Systems : install ‘NVIDIA Nsight Systems’ success
00:49:15 INFO : NVIDIA Nsight Graphics : install ‘NVIDIA Nsight Graphics’ success
00:49:27 INFO : CUDA Toolkit for L4T : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.166_1.0-1_arm64.deb with correct checksum, skip downloading.
00:49:29 INFO : cuDNN on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/libcudnn7_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
00:49:31 INFO : cuDNN on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/libcudnn7-dev_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
00:49:32 INFO : cuDNN on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/libcudnn7-doc_7.3.1.28-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
00:49:32 INFO : OpenCV on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/libopencv_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
00:49:32 INFO : OpenCV on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/libopencv-dev_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
00:49:32 INFO : OpenCV on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/libopencv-python_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
00:49:32 INFO : OpenCV on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/libopencv-samples_3.3.1-2-g31ccdfe11_arm64.deb with correct checksum, skip downloading.
00:49:33 INFO : TensorRT on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/libnvinfer5_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
00:49:33 INFO : TensorRT on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
00:49:40 INFO : TensorRT on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/libnvinfer-samples_5.0.6-1+cuda10.0_all.deb with correct checksum, skip downloading.
00:49:40 INFO : TensorRT on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/tensorrt_5.0.6.3-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
00:49:40 INFO : TensorRT on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/python-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
00:49:41 INFO : TensorRT on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/python-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
00:49:41 INFO : TensorRT on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/python3-libnvinfer_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
00:49:41 INFO : TensorRT on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/python3-libnvinfer-dev_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
00:49:41 INFO : TensorRT on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/graphsurgeon-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
00:49:41 INFO : TensorRT on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/uff-converter-tf_5.0.6-1+cuda10.0_arm64.deb with correct checksum, skip downloading.
00:49:42 INFO : VisionWorks on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/libvisionworks-repo_1.6.0.500n_arm64.deb with correct checksum, skip downloading.
00:49:42 INFO : VisionWorks on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/libvisionworks-sfm-repo_0.90.4_arm64.deb with correct checksum, skip downloading.
00:49:42 INFO : VisionWorks on Target : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/libvisionworks-tracking-repo_0.88.2_arm64.deb with correct checksum, skip downloading.
00:49:43 INFO : Multimedia API : Found file /home/anurag/Downloads/nvidia/sdkm_downloads/Tegra_Multimedia_API_R32.1.0_aarch64.tbz2 with correct checksum, skip downloading.
00:49:51 INFO : [host] [sudo] password for anurag:
00:49:51 INFO :
00:49:51 INFO :
00:49:51 DEBUG : running command < ip addr | grep 192.168.55.100/24 >
00:49:51 ERROR : command terminated with error
00:49:51 DEBUG : running command < lsusb | grep “NVidia Corp” >
00:49:51 ERROR : Could not connect to the target device. Verify that: 1. The device is connected to this host machine with a USB cable. 2. Ubuntu ‘System configuration wizard’ is completed on the device. 3. Jetson’s Ubuntu OS is up and running.
00:49:59 DEBUG : running command < ip addr | grep 192.168.55.100/24 >
00:49:59 ERROR : command terminated with error
00:49:59 DEBUG : running command < lsusb | grep “NVidia Corp” >
00:49:59 ERROR : Could not connect to the target device. Verify that: 1. The device is connected to this host machine with a USB cable. 2. Ubuntu ‘System configuration wizard’ is completed on the device. 3. Jetson’s Ubuntu OS is up and running.
00:50:00 DEBUG : running command < ip addr | grep 192.168.55.100/24 >
00:50:00 ERROR : command terminated with error
00:50:00 DEBUG : running command < lsusb | grep “NVidia Corp” >
00:50:00 ERROR : Could not connect to the target device. Verify that: 1. The device is connected to this host machine with a USB cable. 2. Ubuntu ‘System configuration wizard’ is completed on the device. 3. Jetson’s Ubuntu OS is up and running.
01:29:35 INFO : Device Mode Host Setup in Target SDK : install ‘Device Mode Host Setup in Target SDK’ Skipped
01:29:35 INFO : DateTime Target Setup : install ‘DateTime Target Setup’ Skipped
01:29:35 INFO : CUDA Toolkit for L4T : install ‘CUDA Toolkit for L4T’ Skipped
01:29:35 INFO : cuDNN on Target : install ‘cuDNN on Target’ Skipped
01:29:35 INFO : TensorRT on Target : install ‘TensorRT on Target’ Skipped
01:29:35 INFO : OpenCV on Target : install ‘OpenCV on Target’ Skipped
01:29:35 INFO : VisionWorks on Target : install ‘VisionWorks on Target’ Skipped
01:29:35 INFO : Multimedia API : install ‘Multimedia API’ Skipped
01:29:36 INFO : All done!
I solved the issue. I had been running the flash with an SD card inserted which, I assume, cause the OS to flash on the SD card and the Jetson was never responding after that. When I flashed it again after removing the SD card, the system booted up and worked properly.
