>>>I can compile but not execute the examples.
Could you please provide more information of the detail errors while running CUDA samples on your Jetson TK1 platfrom?
>>>What run file is that?
In CUDA download page(i.e. CUDA 6.5 production release - https://developer.nvidia.com/cuda-downloads). It provides standalone installer(.run file) and RPM/Deb installers for Linux.
when attempting to execute (for this instance: deviceQuery) from the GUI a popup declares:
Could not display “deviceQuery”
There is no application installed for “executable” files.
Do you want to search for an application to open this file?
You are installing the wrong package. The driver for Jetson is coming with the system image.
Follow the instruction at http://elinux.org/Jetson/Installing_CUDA.
Thanks. These instructions are straight-forward, and uncomplicated by host issues.
I followed some similar instructions that didn’t include the usermod part.
I had done these things except I downloaded cuda-repo-l4t-r21.2-6-5-prod_6.5-34_armhf.deb
and substituted 6.5 for 6.0 where necessary. Like I explained, I get the driver version error message.
I am not certain how to diagnose the problem further, or how to respond to it.
Did I get the right package?
Should I uninstall 6.5 and try 6.0? In which case: how do I uninstall 6.5?
I do appreciate your help.
doesn’t this show that cuda runtime and cuda driver are up to date?
ubuntu@tegra-ubuntu:/usr/lib/nvidia$ dpkg --list | grep -i ‘cuda’
ii cuda-command-line-tools-6-5 6.5-34 armhf CUDA command-line tools
ii cuda-core-6-5 6.5-34 armhf CUDA core tools
ii cuda-cublas-6-5 6.5-34 armhf CUBLAS native runtime libraries
ii cuda-cublas-dev-6-5 6.5-34 armhf CUBLAS native dev links, headers
ii cuda-cudart-6-5 6.5-34 armhf CUDA Runtime native Libraries
ii cuda-cudart-dev-6-5 6.5-34 armhf CUDA Runtime native dev links, headers
ii cuda-cufft-6-5 6.5-34 armhf CUFFT native runtime libraries
ii cuda-cufft-dev-6-5 6.5-34 armhf CUFFT native dev links, headers
ii cuda-curand-6-5 6.5-34 armhf CURAND native runtime libraries
ii cuda-curand-dev-6-5 6.5-34 armhf CURAND native dev links, headers
ii cuda-cusparse-6-5 6.5-34 armhf CUSPARSE native runtime libraries
ii cuda-cusparse-dev-6-5 6.5-34 armhf CUSPARSE native dev links, headers
ii cuda-documentation-6-5 6.5-34 armhf CUDA documentation
ii cuda-driver-dev-6-5 6.5-34 armhf CUDA Driver native dev stub library
ii cuda-license-6-5 6.5-34 armhf CUDA licenses
ii cuda-misc-headers-6-5 6.5-34 armhf CUDA misc headers
ii cuda-npp-6-5 6.5-34 armhf NPP native runtime libraries
ii cuda-npp-dev-6-5 6.5-34 armhf NPP native dev links, headers
ii cuda-repo-l4t-r21.2-6-5-prod 6.5-34 armhf CUDA repo configuration files.
ii cuda-samples-6-5 6.5-34 armhf CUDA example applications
ii cuda-toolkit-6-5 6.5-34 armhf CUDA Toolkit 6.5 meta-package
I still get the error message when I try to run deviceQuery:
cudaGetDeviceCount returned 35
-> CUDA driver version is insufficient for CUDA runtime version
Result = FAIL
