[?] Jetson TK1 RMA?
my jetson TK1 is officially dead, and i bought at Nvidia.con… how do i RMA it?
i ran into “exact” same problem as:
[?] Jetson TK1 RMA?
So if you go to http://nvidia.custhelp.com/ and click on chat you should be able to talk to someone from Nvidia. They’ll try to help you and if they can’t find a solution (which is likely since we have the same problem) they’ll probably give you the option to RMA it. That’s the path I took anyways, there could be another method.
