Jetson tx1 cannot boot with HDMI
Hi
when I trying to boot the Jetson tx1 , when I connect the hdmi to the board I get this errors in boot:
[1.058669] tegradc tegradc.1: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
mount: /mnt can't read superblock on /dev/mmcblk2p1
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
I try to flash the jetson but it cannot flash the jetson…
I get these errors from sdkmanager:
12:25:11 ERROR: Flash Jetson TX1 - flash: Error: Return value 8
12:25:11 INFO: Flash Jetson TX1 - flash: Command tegrarcm --download bct P2180_A00_LP4_DSC_204Mhz.bct
12:25:11 ERROR: Flash Jetson TX1 - flash: Failed flashing t210ref.
12:25:11 ERROR: Flash Jetson TX1 - flash: *** ERROR: flashing failed.
12:25:11 ERROR: Flash Jetson TX1 - flash: [exec_command]: /bin/bash -c /home/behyar/.nvsdkm/replays/scripts/JetPack_4.6.6_Linux/NV_L4T_FLASH_TX1_WITH_OS_IMAGE_COMP.sh; [error]: *** ERROR: flashing failed.
12:25:11 INFO: Flash Jetson TX1 - flash: [ Component Install Finished with Error ]
12:25:11 INFO: Flash Jetson TX1 - flash: [host] [ 5.48 MB released. Disk Avail on Partition /dev/sdb2: 173.10 GB ]
12:25:11 INFO: Flash Jetson TX1 - flash: [ NV_L4T_FLASH_TX1_WITH_OS_IMAGE_COMP Install took 2m0s ]
12:25:11 ERROR: command error code: 11
12:25:11 ERROR: Flash Jetson TX1 - flash: command terminated with error
**12:25:11 SUMMARY: Flash Jetson TX1 - flash: First Error: Installation failed** ```
Actually, you should not dump log in such way. If you want to share log, share the full logs.
I only saw few lines here and they just told me failure. We all knew there are some failures otherwise you won’t come to file topic. Such log didn’t help. We need the context before that to tell what is wrong.
the only text’s that I see is this…
when I power up the board, these messages come up and nothing happened…
Please follow this page to learn how to operate the console and dump log.
Also, where are you trying to boot this device? eMMC? For that partial log, I saw your rootfs seems not able to be mounted.
This issue has nothing to do with HDMI, even without HDMI, your system cannot boot.
