Also with HDMI I never reach the GUI it shows the following message
16.500782] vdd-1v8: voltage operation not allowed
[ 16.506052] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 16.533021] vdd-1v8: voltage operation not allowed
[ 16.538338] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 16.565843] vdd-1v8: voltage operation not allowed
[ 16.571207] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 16.580791] vdd-1v8: voltage operation not allowed
[ 16.586179] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 16.694728] vdd-1v8: voltage operation not allowed
Is there something wrong with hardware? Any suggestions?
On newer releases the accounts do not exist by default until you do a first login setup. Have you flashed? If so, then this is why since there wouldn’t be any “nvidia” or “ubuntu” account until you create it.
For newly shipped units I do not know if “first boot” still has you create accounts, or if something older is still on the unit. However, if newer software is shipped, then this is probably the same issue. However, it is safe to say the hardware is working and that this is a purely software issue.
Would someone be able to say if newly shipped TX2 dev kits require any kind of first login setup?
Either way, if you were to flash a recent release (recommended anyway even without this issue), then you’d have a chance to complete the first boot setup.
Hi, i’m facing the same issue. What you mean with “I flashed the Jetpack 4.2 and everything works.”, where can I get this step by step?
I’m trying to do the setup from the sdk manager on my linux host, but it is asking for a login to my jetson. I dont have this password since nvidia / nividia is not being accepted as valid.
Flash Jetpack is a different step from what i’m trying to do with the sdk manager?
after Flash Jetpack , You need to first add a monitor and keyboard to the TX2. and setup the
TX2 user account and then try flashing the SDK.
I had the issue with the ssh when using wifi,it would not staying connected, it kept dropping off.
After the 3rd try of flashing, i realized it was the Network Manger issue,
So i removed network-manager then
sudo apt-get install network-manager
sudo service NetworkManager start #added my network password
sudo nmcli device wifi connect ‘xxxRouterIDxx’ password ‘AxxxxxM’
sudo shutdown -r now
It would be better to post in the Xavier forum, but in this case there is no difference between an Xavier and a TX2. Did you have a monitor and keyboard attached during the flash, and then when the Jetson reboots automatically at the end of the flash, did you create the login account name/pass?
