Jetson TX2 NX problem with UART communication and flash
Hi, I have a problem with uart communication jetson tx2 nx. When I send data from jetson, on the computer I do not receive any data,and on reboot I get messages - I have exactly the same problem as here: TX2 NX RS232 Communication Problem.
I managed to enable THS2 with /boot/tegra186-p3636-0001-p3509-0000-a01-user-custom.dtb (at my place I have a different file) and disable bpmp-dtb port with /Linux_for_Tegra/bootloader/tegra186-bpmp-quill-p3310-1000-a00-00.dtb (also a different file), however I am not able to perform flash - Error: Invalid target board appears. I tried with:
jetson-xavier-nx-devkit-tx2-nx
jetson-xavier-nx-devkit-emmc
jetson-agx-xavier-devkit
jetson-agx-xavier-industrial
jetson
unfortunately none of these work, how do I make a flash?
Hi scoob219,
Are you using the devkit or custom board for TX2-NX?
Which UART interface are you using?
Please share the full dmesg and device tree for further check.
This should be the correct board config for TX2-NX.
