an error is reported when the system starts:
usb usb2-port3: config error
usb 1-2: New USB device found, idVendor=2676, idProduct=ba02
usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Now my device cannot be mounted to the USB 3.0 interface, but mounted to the USB 2.0 interface. After I executed the sudo reboot command, everything was normal. What is the reason for the problem?
What is your device tree setting? Did you ever change it?
