Hello Everyone. I have this “old” Xavier AGX, which gives me
when trying to boot it up. I’ve tried to putting it into recovery mode, but when I do it, the monitor just stays black and my ubuntu host doesn’t recognize any new device. Is there anything that I can do?
Hi @benedetto.benzi.scdless,
The first error message you seem to be getting suggests that there might be some memory issue. Is it possible for you to try reflashing? Also, have you tried using a UART serial monitor to see if the bootloader logs show some more information?
Regards,
Francis Guindon
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
My problem with reflashing the OS is that I need to do it from NVIDIA SDK Manager, but the device is not recognized (and yes, the cable is connected to the usb-c above the power plug), therefore I cannot flash the OS again (which could’ve been a good solution).
I’ll try the serial monitor option if I find a suitable one to connect, thank you for your help and your time.
