I have recently experience boot failure on three of my nvidia jetson xaviers and I am unsure of what the cause is. Anytime I try to boot it up just nothing happens, none of the peripherals appear to be working anymore (no display, network, nothing). I am able to connect over uart, but all unlike my other functioning jetsons, these three just display garbage information (see image below for example). Is something like this fixable even though I am unable to get any bearing on what the issue even is. Any advice or assistance on this matter is greatly appreciated!
I have already tried that, but the sdkmanager is not even able to detect them. the only way I am able to access the devices and get anything is using the rx/tx pins on J14.
So it looks like it does get detected, I will attempt to re-flash them and let you know what happens. Its strange though, on one of these jetson dev kits, the power led does not turn on (we use this as an indicator if the jetson is on or not), but it was detected by sdkmanager
Have the device been reflashed successfully?
Any result can be shared?
