The micro-USB is “hot plug”. You could disconnect it and reconnect the cable and the problem might go away.
If you are not using the cable which comes with the dev kit, then I would be suspicious of cable quality (charger cables very rarely work well for data).
You could also test the same thing to another computer and find out if the problem transfers to other computers as well.
This happened to me too. NX is running a DHCP server that automatically assign IP address 192.168.55.100 to your Windows host when connecting with the USB. I don’t know it is Windows driver issue or not but I ran into the same issue in some Windows 10, particularly those Windows 10 that has been upgraded to 1903 or later version. What I did to get around this issue is to assign a static IP address on the Windows end, for example, 192.168.55.55, and that works fine.
It is also came to my attention that this issue may happen more often if the Windows end USB is a USB-C. You may try connect to a USB-A port to see if that mitigate the problem.
You are probably in the right area for the topic, but rather than being a driver issue, I think it is a security setup issue. If the host PC (regardless of being Linux or Windows or Mac) is set up to not allow plugging in network devices and configuring them by default for security reasons, then the host PC would need a setting change for this. Setting up as DHCP or static is probably part of that setup.
