I am currently designing a carrier board for the Xavier NX, where the Ethernet needs to be connected to an Ethernet-Switch (Marvell 88E6352). Due to the lack of space in my design I am not able to use magnetics.
Does the NX support the usage of 100nF capacitors in series instead of magnetics? Or is there a better way to solve this Problem?
Thank you for your help
