If the following timing sequence is satisfied, does NX support sudden power down.
What do you mean about it? It is the power down sequence of sudden power loss.
In the terminal device,Jetson Nx shutdown is all sudden power loss, whether there will be abnormal or damage .
No if the sequence is satisfied.
After testing, repeated sudden power loss will cause the files in the TF card to be lost
Does jetson NX have relevant documents and instructions for sudden power failure? After testing, TX2 suddenly power off will not cause problems, but NX will have problems, TF will lose data, and startup will be abnormal.
It is stated in OEM DG as you listed the sudden power loss request. So please follow it to make related NX design.
