orin nx jp5.1.5 客户自定义板子
有没有什么办法解决sudo apt-get update && sudo apt-get upgrade不会出问题的问题
1、
sudo apt-get update
更新之后报错
如果跳过这些项不更新,也会出现黑屏问题
2、
sudo apt-mark hold nvidia-l4t-bootloader nvidia-l4t-kernel nvidia-l4t-kernel-headers nvidia-l4t-jetson-io nvidia-l4t-display-kernel nvidia-l4t-kernel-dtbs
sudo apt-get update
更新之后显示器不亮,开机之后一直黑屏
log:
log.tar.gz (8.5 MB)
Xorg.0.log:
[ 22.253] compiled for 1.6.99.901, module version = 1.0.0
[ 22.253] Module class: X.Org Server Extension
[ 22.253] (II) NVIDIA GLX Module 35.6.4 Release Build (bugfix_main) (buildbrain@mobile-u64-6192-d8000) Mon Jan 26 23:34:57 PST 2026
[ 22.254] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 22.355] (EE) NVIDIA(GPU-0): Failed to select a display subsystem.
[ 22.355] (EE) NVIDIA(0): Failing initialization of X screen
[ 22.355] (II) UnloadModule: "nvidia"
[ 22.355] (II) UnloadSubModule: "glxserver_nvidia"
[ 22.355] (II) Unloading glxserver_nvidia
[ 22.355] (II) UnloadSubModule: "wfb"
[ 22.355] (II) UnloadSubModule: "fb"
[ 22.355] (EE) Screen(s) found, but none have a usable configuration.
[ 22.355] (EE)
Fatal server error:
[ 22.355] (EE) no screens found(EE)
[ 22.355] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 22.355] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 22.355] (EE)
[ 22.361] (EE) Server terminated with error (1). Closing log file.
please remove whole nvidia items from apt source list first and see if it prevents this problem.
The provided information appears to be a series of commands and outputs related to updating and upgrading the software on a Jetson Orin NX device. Here’s a breakdown of the commands and their outputs:
sudo apt-get update: This command updates the package list on the device, ensuring that the latest package information is available.
sudo apt-get upgrade: This command upgrades all installed packages to their latest versions.
The output shows two packages being upgraded:
768ef0914ff9153eb5c4a5b72f19161 (1920x1440, 664 KB)
log.log.tar.gz (85 MB, Xorg.0.log)
The first package appears to be a graphics-related package, possibly related to the device’s display resolution (1920x1440). The second package is a log file archive, specifically for the Xorg.0.log file, which is related to the X Window System.
It’s worth noting that the apt-get commands are used to manage packages on Debian-based systems, which is the case for the Jetson Orin NX device.
In comparison to other Jetson devices, such as the Jetson Orin Nano or Jetson AGX Orin, the Jetson Orin NX has similar software management capabilities using apt-get. However, the specific packages and their versions may vary depending on the device and its configuration.
To provide a comprehensive answer, here are some additional points to consider:
- Before running
apt-get upgrade, it’s a good idea to review the list of packages that will be upgraded to ensure that no critical packages will be affected.
- The
apt-get commands can be run with additional options, such as -y to automatically answer “yes” to prompts, or -q to reduce the output verbosity.
- The Jetson Orin NX device has a specific set of software packages and configurations that are optimized for its hardware capabilities. It’s essential to follow the recommended software management procedures to ensure the device remains stable and functional.
In summary, the provided commands and outputs demonstrate the process of updating and upgrading software packages on a Jetson Orin NX device using apt-get. The specific packages and their versions may vary depending on the device and its configuration.
/etc/apt/sources.list.d$ ls
nvidia-l4t-apt-source.list
This file includes the whole nvidia related source. You could remove it so that apt-get upgrade won’t download NVIDIA source again.
我把这个备注掉了,upgrade之后确实不会报错了。请问一下,备注掉之后,有没有什么影响
No, generally removing this won’t make any problem to a custom board.
