I encounter a crash in the xudc driver when attempting to add more than one PHYs to the xudc@355000 node. Could you guide me on the proper method to configure this node?
We’re working with a custom board derived from Jetson Orin Nano, which includes two USB-C ports. Our aim is to set the data-role for both ports as dual.
tegra_xudc: xudc@3550000 {
phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-0}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-1}>,
<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-1}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-0}>;
phy-names = “usb2-0”, “usb3-1”, “usb2-1”, “usb3-0”;
[ 5.255327] hub 1-0:1.0: 4 ports detected
[ 5.259740] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 5.267729] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.274984] usb usb2: Product: xHCI Host Controller
[ 5.279973] usb usb2: Manufacturer: Linux 5.10.192-l4t-35.5.0+g86e0ef868c78 xhci-hcd
[ 5.287770] usb usb2: SerialNumber: 3610000.xhci
[ 5.293054] hub 2-0:1.0: USB hub found
[ 5.296354] hub 2-0:1.0: 4 ports detected
[ 5.304805] ------------[ cut here ]------------
[ 5.305084] double register detected
[ 5.305154] WARNING: CPU: 5 PID: 134 at kernel/notifier.c:27 notifier_chain_register+0x5c/0x90
[ 5.317334] Modules linked in:
[ 5.320404] CPU: 5 PID: 134 Comm: kworker/5:3 Not tainted 5.10.192-l4t-35.5.0+g86e0ef868c78 #1
[ 5.328707] Hardware name: NVIDIA COGNEX PEREGRINE NONE NONE/Jetson, BIOS v35.5.0 02/26/2024
[ 5.337303] Workqueue: events deferred_probe_work_func
[ 5.342451] pstate: 60c00089 (nZCv daIf +PAN +UAO -TCO BTYPE=–)
[ 5.348393] pc : notifier_chain_register+0x5c/0x90
[ 5.353383] lr : notifier_chain_register+0x5c/0x90
[ 5.358194] sp : ffff80001182bad0
[ 5.361607] x29: ffff80001182bad0 x28: 000000000000001f
[ 5.366770] x27: ffff011145a93914 x26: ffffa26292b52580
[ 5.372194] x25: ffffa26294999aa0 x24: 0000000fffffffe0
[ 5.377617] x23: ffff011145a93a80 x22: 0000000000000001
[ 5.383130] x21: 0000000000000001 x20: ffff01114598d1c8
[ 5.388555] x19: ffff011145a93a80 x18: ffffffffffffffff
[ 5.394068] x17: 0000000000000000 x16: 0000000058e591f9
[ 5.399581] x15: ffff80009182b6a7 x14: 0000000000000006
[ 5.404917] x13: ffff80001182b6af x12: 0000000000000038
[ 5.410344] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f
[ 5.415855] x9 : ffffa262947a7b60 x8 : 00000000ffffefff
[ 5.421193] x7 : ffffa262947ffb60 x6 : 000000000000b5d8
[ 5.426531] x5 : fffffffffffe8538 x4 : 0000000000000fff
[ 5.431957] x3 : 00000000ffffffff x2 : 0000000000000000
[ 5.437294] x1 : 0000000000000000 x0 : ffff01129859bb00
[ 5.442634] Call trace:
[ 5.445086] notifier_chain_register+0x5c/0x90
[ 5.449368] atomic_notifier_chain_register+0x38/0x60
[ 5.454462] tegra_xudc_probe+0xa84/0xd04
[ 5.458650] platform_drv_probe+0x5c/0xb0
[ 5.462669] really_probe+0xf8/0x4ec
[ 5.466170] driver_probe_device+0x60/0xf0
[ 5.470194] __device_attach_driver+0xb8/0x120
[ 5.474659] bus_for_each_drv+0x8c/0xe0
[ 5.478419] __device_attach+0xb4/0x1c4
[ 5.482181] device_initial_probe+0x28/0x34
[ 5.486208] bus_probe_device+0xa4/0xb0
[ 5.490145] deferred_probe_work_func+0x90/0xc4
[ 5.494700] process_one_work+0x1d8/0x4d0
[ 5.498720] worker_thread+0x2c0/0x490
[ 5.502482] kthread+0x160/0x164
[ 5.505902] ret_from_fork+0x10/0x18
[ 5.509393] —[ end trace b2c1294528f437f2 ]—
[ 5.517994] at24 0-0050: supply vcc not found, using dummy regulator
[ 5.520727] at24 0-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 5.532278] irq: IRQ283: trimming hierarchy from :pmc@c360000
[ 6.331862] at24 7-0053: supply vcc not found, using dummy regulator
[ 6.332372] at24 7-0053: 256 byte se97b EEPROM, writable, 1 bytes/write
[ 6.335749] i2c i2c-2: Added multiplexed i2c bus 9
[ 6.336577] i2c i2c-2: Added multiplexed i2c bus 10
[ 6.336726] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 6.337206] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[ 6.350300] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1616000 KHz, changing to: 1510400 KHz
[ 6.352195] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1582000 KHz, changing to: 1510400 KHz
[ 6.353271] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
