Kit 106: OM-118661: Remove physics exts
It seems, as of Kit 106, the Physx extensions have been removed.
Can someone clarify this decision and speak to the future options for reengaging the historical Phsyx functionality in Kit Apps built from the Template?
Hi. Thanks for reading the release notes!
In this case - PhysX extension code was removed from the main Kit git repository and put into a separate repository. PhysX is still supported and not going anywhere.
Kit 106.0.0 Beta released with only the PhysX runtime extensions - and the rest of the extensions (for UI and editing features) are in the process of being released with updated Kit App Template for general availability on 106.0.1.
If only it was a simple web page read that brought me here.
Imagine my surprise when I pulled down the App Template and followed the instructions to Build it, only to finally Launch and find a naked OV App.
Breadcrumbs: if you anyone reading this is looking for Kit 106 + Physx, install the IsaacSim Application.
So i´m using the 106.0.2 and using the new extension registry https://ovextensionsprod.blob.core.windows.net/exts/kit/prod/106/shared , but i still can´t see the rest of the extension
It still needs to be updated in the registry. I will let you know when. Hopefully within about 1 month.
