Hello everyone,
Last time I tried to connect the hardware like in the title, but I couldn’t install it successfully. I use:
- LattePanda Sigma 32GB with Ubuntu 24.04.1 LTS and X11 (not Wayland)
- eGPU eGFX Breakaway Box 550
- NVIDIA Asus RTX 3060 V2 DUAL OC 12 GB
- connection between LattePanda Sigma and eGPU via Thunderbolt 4 cable (eGPU is using Thunderbolt 3)
Has somebody tried to connect eGPU via Thunderbolt to Lattepanda Sigma on the Ubuntu system?
I tried to do this but I have a problem with drivers.
I installed Windows 10 on LattePanda Sigma and eGPU has been detected. I was able to switch on hardware acceleration for the web browser. 8K video on a 4K display connected to LattePanda Sigma via HDMI works very well. The display connected directly to the eGPU works also.
So now there can be a problem on Ubuntu with the NVIDIA driver because in general NVIDIA is recognized. Or maybe there is a conflict between the integrated GPU and NVidia card on the Ubuntu system. I checked that the Lenovo Thunderbolt 4 Dock works with LattePanda on Ubuntu (so Thunderbolt works with Ubuntu).
Sometimes, it’s strange because I have to switch off/on the eGPU a few times. After all, the lights on NVIDIA are on. After all, the system does not recognize it.
And after I have to reboot Ubuntu.
In general, Ubuntu recognizes NVIDIA but I can’t Install the driver properly.
I found a few tutorials on the Web and I made everything step-by-step to install the NVIDIA driver.
https://www.if-not-true-then-false.com/2021/debian-ubuntu-linux-mint-nvidia-guide/
How to uninstall Nvidia driver and install the latest driver in Ubuntu | by WMSmile | Medium
CUDA 6.5 on AWS GPU instance running Ubuntu 14.04 - Seven Story Rabbit Hole
Every time I faced with strange issue
ERROR: Unable to load the kernel module ‘nvidia.ko’. This happens most frequently when this kernel module was built against the wrong or improperly configured kernel sources, with a version of gcc that differs from the one used to build the target kernel, or if another driver, such as nouveau, is present and prevents the NVIDIA kernel module from obtaining ownership of the NVIDIA GPU(s), or no NVIDIA GPU installed in this system is supported by this NVIDIA Linux graphics driver release.
Please see the log entries ‘Kernel module load error’ and ‘Kernel messages’ at the end of the file ‘/var/log/nvidia-installer.log’ for more information.
Has somebody faced with the same issue? I am very thankful for every tip, and advice. I don’t have any idea how to solve this issue and connect this hardware.
Best regards
