Downloaded L4T Driver Package (BSP) Sources from https://developer.nvidia.com/embedded/linux-tegra (SHA1Sum verified)
Compiled and installed as instructed v4l2_libs_src libv4lconvert & libv4l2
Ran $ gst-inspect-1.0 on a clean brand new Jetson SDK Developer Kit SD card image.
$ gst-inspect-1.0
(gst-plugin-scanner:19717): GStreamer-WARNING **: 17:53:13.461: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstzbar.so': /usr/lib/aarch64-linux-gnu/libv4lconvert.so: undefined symbol: v4lconvert_helper_cleanup
(gst-plugin-scanner:19717): GStreamer-WARNING **: 17:53:13.499: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so': /usr/lib/aarch64-linux-gnu/libv4lconvert.so: undefined symbol: v4lconvert_helper_cleanup
(gst-plugin-scanner:19717): GStreamer-WARNING **: 17:53:13.789: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideo4linux2.so': /usr/lib/aarch64-linux-gnu/libv4lconvert.so: undefined symbol: v4lconvert_helper_cleanup
Tried to recompile; this time moved the include/*.h files into /usr/local/include/, make cleanup, make and removed the file ~/.cache/gstreamer-1.0/registry.aarch64.bin so I can run again get-inspect and reload the elements. However the problem pop-up again…
