Hello to everyone,
I’ve upgraded the L4T from 32.1.2 to 32.5.1 by removing the sources located on /etc/apt/sources.list.d/nvidia-l4t-apt-source.list and using these new sources :
deb https://repo.download.nvidia.com/jetson/common r32.5 main
deb https://repo.download.nvidia.com/jetson/t210 r32.5 main
and then I gave apt-update & apt-upgrade
it worked,but unfortunately an error is occurred and I don’t know how to fix it. Can u give a look at the log below and please give me some suggestion for fixing the error ? thanks.
root@zio-desktop:/home/zio/Scrivania/Work/I9/Android-arm# apt upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin
dpkg-repack efibootmgr gir1.2-geocodeglib-1.0 gir1.2-timezonemap-1.0
grub-common kde-window-manager kinit kio kpackagetool5 kpartx kwayland-data
kwin-common kwin-data kwin-x11 libabw-0.1-1 libcdr-0.1-1
libclucene-contribs1v5 libclucene-core1v5 libcmis-0.5-5v5 libcolamd2
libdebian-installer4 libe-book-0.1-1 libeot0 libepubgen-0.1-1
libetonyek-0.1-1 libexttextcat-2.0-0 libexttextcat-data libfreehand-0.1-1
libfwup1 libkdecorations2-5v5 libkdecorations2private5v5 libkf5activities5
libkf5attica5 libkf5completion-data libkf5completion5 libkf5declarative-data
libkf5declarative5 libkf5doctools5 libkf5globalaccel-data libkf5globalaccel5
libkf5globalaccelprivate5 libkf5idletime5 libkf5jobwidgets-data
libkf5jobwidgets5 libkf5kcmutils-data libkf5kcmutils5 libkf5kiocore5
libkf5kiontlm5 libkf5kiowidgets5 libkf5newstuff-data libkf5newstuff5
libkf5newstuffcore5 libkf5package-data libkf5package5 libkf5plasma5
libkf5quickaddons5 libkf5solid5 libkf5solid5-data libkf5sonnet5-data
libkf5sonnetcore5 libkf5sonnetui5 libkf5textwidgets-data libkf5textwidgets5
libkf5waylandclient5 libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data
libkf5xmlgui5 libkscreenlocker5 libkwin4-effect-builtins1 libkwineffects11
libkwinglutils11 libkwinxrenderutils11 libllvm8 libmhash2 libmspub-0.1-1
libmwaw-0.3-3 libmythes-1.2-0 libneon27-gnutls libodfgen-0.1-1
liborcus-0.13-0 libpagemaker-0.0-0 libqgsttools-p1 libqt5designer5
libqt5help5 libqt5multimedia5 libqt5multimedia5-plugins
libqt5multimediaquick-p5 libqt5multimediawidgets5 libqt5opengl5
libqt5quickwidgets5 libqt5sql5 libqt5test5 libraptor2-0 librasqal3 librdf0
librevenge-0.0-0 libsuitesparseconfig5 liburcu6 libvisio-0.1-1
libwpd-0.10-10 libwpg-0.3-3 libwps-0.4-4 libxcb-composite0 libxcb-cursor0
libxcb-damage0 libxmlsec1 libxmlsec1-nss lp-solve os-prober
python3-dbus.mainloop.pyqt5 python3-icu python3-pam python3-pyqt5
python3-pyqt5.qtsvg python3-pyqt5.qtwebkit python3-sip
qml-module-org-kde-kquickcontrolsaddons qml-module-qtmultimedia
qml-module-qtquick2 rdate sg3-utils-udev tasksel tasksel-data
Use 'apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up vpi1-demos (1.0.15) ...
ln: failed to create symbolic link '/usr/share/gnome:/usr/share/cinnamon:/usr/local/share/:/usr/share/:/var/lib/snapd/desktop/applications/vpi1_demos': No such file or directory
dpkg: error processing package vpi1-demos (--configure):
installed vpi1-demos package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of nvidia-vpi:
nvidia-vpi depends on vpi1-demos (= 1.0.15); however:
Package vpi1-demos is not configured yet.
dpkg: error processing package nvidia-vpi (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nvidia-jetpack:
nvidia-jetpack depends on nvidia-vpi (= 4.5.1-b17); however:
Package nvidia-vpi is not configured yet.
dpkg: error processing package nvidia-jetpack (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
Errors were encountered while processing:
vpi1-demos
nvidia-vpi
nvidia-jetpack
E: Sub-process /usr/bin/dpkg returned an error code (1)
below u can read some informations on my system :
root@zio-desktop:/home/zio/Scrivania/Work/I9/Tools/jetsonUtilities# ./jetsonInfo.py
NVIDIA Jetson Nano (Developer Kit Version)
L4T 32.5.1 [ JetPack UNKNOWN ]
Ubuntu 18.04.5 LTS
Kernel Version: 4.9.201+
CUDA 10.2.89
CUDA Architecture: 5.3
OpenCV version: 4.1.1
OpenCV Cuda: NO
CUDNN: 8.0.0.180
TensorRT: 7.1.3.0
Vision Works: 1.6.0.501
VPI: ii libnvvpi1 1.0.15 arm64 NVIDIA Vision Programming Interface library
