I am trying to use a Logitech Gamepad F710 on a jetson TX2 on xinput mode. I did follow the following thread.
However my problem is slightly different.
The joystick isn’t recognized on startup. After I change the toggle from xinput to direct input on the joystick, the /dev/input/js0 file is created. If I change it back to xinput, the js0 file disappears.
The joystick works fine in direct input mode. Again, it is recognized only after I start up the jetson and toggle the button on the joystick to x and back to d.
On checking the /proc/config.gz file, CONFIG_LOGITECH_FF is set to y.
I require my joystick to work on xinput mode and has to be recognized on startup itself without me having to toggle it back to x and d again.
Would following the steps in the above link solve my problem as well? I would greatly appreciate any help on this.
Thank you!
