Looking for AI Platform Based on NVIDIA® Jetson Orin NX with the following specifications
We are planning to purchase an AI Platform Based on NVIDIA® Jetson Orin NX with the following specifications:
o Memory for NVIDIA Module: Minimum 16 GB
o Storage: NVMe SSD with a minimum capacity of 512 GB
o Power Supply: Must be compatible with NVIDIA® Jetson Orin NX module
o Display: Portable full HD display (15” or larger) compatible with NVIDIA® Jetson Orin NX module with USB-C power supply and charge back support
o Enclosure: Enclosure specifically designed for the Jetson Orin NX module
o Uninterruptible Power Supply (UPS): 600VA UPS
o Network Adapter: Wi-Fi adapter
o Cooling System: Efficient cooling solution (heat sinks and/or fans)
o Cables and Connectors: HDMI, USB, and other necessary cables
o Input Devices: Compatible wireless keyboard and mouse
o Additional Storage: 512 GB SD card, UHS-1 class or better
o Carrier Board: Must be compatible with NVIDIA® Jetson Orin NX module, with 16 GB memory, HDMI support, 2x CSI 4-lane or 4x CSI 2-lane support, with power adapter.
Please suggest specific MPNs/part numbers for each of the above specifications.
Regarding Orin MX technical spec, please check Jetson Modules, Support, Ecosystem, and Lineup | NVIDIA Developer
For Orin NX partner number, please refer to Jetson FAQ | NVIDIA Developer
For the support components, please refer to Jetson Orin NX Series and Jetson Orin Nano Series Supported Component List
@kayccc
Thank you so much.
